Author Topic: fault codes  (Read 1029 times)
davie b
  • greetland halifax
fault codes
« on: 15 November 2011, 10:29:34 »
Hi all I have just used a fault code reader op com on my 98 2.5 diesel est it came up with 15/44/64 how do I rectify the faults?
15 coolant temp high voltage
44 incorrect boost pressure
64 fuel quantity control out of range
Dave :'(
Re: fault codes
« Reply #1 on: 15 November 2011, 18:19:43 »
Are they current faults, or historic?
Clear them out, see what comes back.
If they do, try the following:
15 - check the wiring around the CTS, some dumbos fitted those stupid egay "chips" resistors....
44 - check sensors for blockages, and check the wastegate moves freely
64 - fill the fuel filter with Diesel Magic, and see what happens onces thats run through (30s or so)
davie b
  • greetland halifax
Re: fault codes
« Reply #2 on: 16 November 2011, 00:15:35 »
I ve just got in from work and read your answers.
I believe it had the hot start fix done before I purchased the car last November where would I find the device as not very clued up on these vehicles.
any schematics regarding the wastegate and sensors?
I fitted a new fuel filter 4000 miles ago and filled with diesel magic at that time.
I cleared faults but they came back straight away so are current.
Unfortunately any work will have to wait until a week today as work and the fact my son is borrowing the car for the weekend means I can't even look on Sunday. :-\
