interior Light
Started by Kaycee, 18 November 2011, 07:52:21
Kaycee
Hi all
Probably daft question i need to change a bulb in overhead  interior light but not sure how it comes out
what size is it does it push and turn or is it capless
dealer says it a festoon bulb but it def is a normal bulb but a smallish head
3,2 elite 2002
thanks
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Quote from: Kaycee on 18 November 2011, 07:52:21
Hi all
3,2 elite 2002
thanks
This is inside mine if that's of any use, but mine's the preface lift including the mic for the phone.
Pretty sure they are all glass wedge base push-in bulbs in the black 1/2 turn holders  :-\
Kaycee
thanks for that andy
but i still cant weigh up how to remove the bulb . Has all that printed circuit got to come out if so how
i am suprised no one has changed one
thanks
The bulb holders are 1/4 turn bayonnet fitting, just like all instrument lamps in the dashboard (but bigger)
Kaycee
so the circuit board as to be removed then
but how
bored bigyin54
no just turn the bulb holder
Kaycee
i've got to be thick. when i take off the cover all i xan see is the bulbs in the unit are you saying i turn the bulb
turn the bulb about 45 degree's ish, it will then drop out  :)
fiend61
ummm have you somehow prised the plastic lens off instead of taking the whole light fitting out ???? :P
I_want_an_Omega
isnt there a black plastic cover over the holders that has been removed prior to the picture being taken?
Omega_Dan
Quote from: Kaycee on 19 November 2011, 15:15:55
Don't turn the bulb but the black plastic case that holds the bulbs in place, as per the picture.  :y
Quote from: Lincs Robert on 19 November 2011, 20:06:27
I took the photo's a number of years ago ................. the other photo's were to do with a missing phone mic. .......... I've slept since so can't remember specifics. It won't be difficult though.  ;) ;) ;)
Kaycee
Thats exactly what i have done ive prised off the plastic clear lens cover (as per the hand book) which as exposed the 4 bulbs. But as my first post said , i cant see how the bulbs will come out. If the whole light unit as to come out what im asking is how does it come out to expose the bulbs as in the photo.
Surely GM wouldnt have made it this awkward to change a bulb looks like i'm going to have to live with one of the bulbs blown.
Thanks for advice
Robert
fiend61
the whole light fitting is just clipped in , carefully get a screwdriver and prise the whole lot out  :y
QuoteSurely GM wouldnt have made it this awkward to change a bulb
you had better believe it buddy, try changing headlamp bulbs in a vec-c  :o also when you start working on your car you will see how awkward vauxhall can be  ::)
Quote from: fiend61 on 20 November 2011, 07:31:08
Ain't that the truth. Air filter housing out for the drivers side ::) F/L Indicator lamps are potentially a bumper off job if you've got fat fingers...
