Author Topic: HELP ASAP! Oil Leak?  (Read 3103 times)
tommyboy1289
  • Doncaster
    • '99 Omega 2.0i 16v CDX
« on: 22 November 2011, 16:29:30 »
evening guys,
just bought an omega, and accepted a new job 33 miles away to fund it, but already i've got a huge oil leak.
Had a nosy about and all i can say is it's leaking somewhere above the gearbox? anybody got any advice,
Also do we have any mechanics/members in doncaster/sheffield/wetherby area that could fix it if it's not simple?
thanks in advance
Classic Quote
Girlfriend - "Babe, this is a 40"
Me - "It's ok, i'm only doing 70"
andyc
  • Norfolk
Re: HELP ASAP! Oil Leak?
« Reply #1 on: 22 November 2011, 16:34:25 »
Being a four pot i'd say its the cam cover gasket, give it a wash down and have another look. Not a hard job to fix yourself if you which end of a spanner is which.
If this is the problem i'd also suggest fitting a breather box to the crank vent pipe
Cheers
Andy
Thetford. Norfolk
« Reply #2 on: 22 November 2011, 16:34:55 »
Possible camcover gasket. Whip the plugs out, if wells are full of oil there`s your oil leak
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #3 on: 22 November 2011, 16:36:16 »
  that leaves alot to go at  ;D
have you removed plug leads and checked for oil in wells ?  could be camcover gaskets
other than that need some more info on where it is leaking from  :y
fiend61
  • york
  • each to their own
« Reply #4 on: 22 November 2011, 16:36:48 »
grrrrrrrrrrrrrrrr must type faster  ::)
tommyboy1289
  • Doncaster
« Reply #5 on: 22 November 2011, 16:38:57 »
Havent looked there yet, not very mechanically minded, if i can see where its leaking from then i can pull apart and re-fit but no good at diagnostics.
Will check in the spark plugs tomorrow, would it sound any different? and how much are the camcover gaskets roughly?
thanks guys  :y
Classic Quote
fiend61
  • york
  • each to their own
« Reply #6 on: 22 November 2011, 16:42:35 »
i am near to donny tomorrow if you want a second opinion and/or a hand  :y
tommyboy1289
  • Doncaster
« Reply #7 on: 22 November 2011, 16:43:20 »
What time you around pal? gotta pop to wetherby at some point
Classic Quote
fiend61
  • york
  • each to their own
« Reply #8 on: 22 November 2011, 17:21:52 »
tomorrow morning about 10ish if thats any good or could meet you in wetherby
tommyboy1289
  • Doncaster
« Reply #9 on: 22 November 2011, 17:50:28 »
Ill pm you my mobile number pal  :y
Classic Quote
tommyboy1289
  • Doncaster
« Reply #10 on: 23 November 2011, 17:29:52 »
THANKYOU!
Cheers for popping round today pal, if it's correct I phoned car parts place, he said its a rubber strip type gasket, and mentioned rocker cover but dont think were on par,
What do you think?
Classic Quote
Simon72
  • Wolverhampton
« Reply #11 on: 23 November 2011, 17:36:12 »
Cam-cover / Rocker-cover are the same thing if thats what is confusing you ;-)
And yes it is RUBBER
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #12 on: 23 November 2011, 17:39:14 »
Use gen vx cam cover seals or you will be doing them again in a couple of months.
Gary.
Jaguar XJ6
tommyboy1289
  • Doncaster
« Reply #13 on: 23 November 2011, 17:45:37 »
Is it this one?
http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_CAM_COVER_GASKET_-_90511451N.html
How many of the little rubber o-rings will I need?
Cheers guys
Classic Quote
« Reply #14 on: 23 November 2011, 17:48:23 »
Is it this one?
Cheers guys
Nope, that`s a copy. You`ll need 8 "O" rings
