Brand new CID tech2 programming ?
Started by omegafin, 23 November 2011, 21:29:54
omegafin
Quote from: TheBoy on 24 November 2011, 18:46:00
You need the pairing code used to pair the NCDC, CDC3, Telematics (if applicable) and CID.  If it was factory fitted, and unmolested, this will be on the car's carpass.  However, I doubt it was factory fitted - but can check from registration.
If you don't have pairing code, then, assuming it was all properly paired beforehand, I can decode it, and then pair in new CID.
NCDC 2013 + CID + NAVI are factory fitted
So pairing code is not same as display code ?
Pairing code is in Car pass ? ( my pass is lost )
So I have to order naw pass ?
so where these display codes are needed
http://www.opel-infos.de/downloads/omega_b_display.pdf
And where instrument code is needed ( you can select kmh/mph )
but why tires are involved in both codes ??
http://www.opel-infos.de/downloads/omega_b_instrument.pdf
Code Index (programming config) has absolutely nothing to do with security pairing codes.
If the NCDC is factory fitted, and hasn't been changed/swapped/buggered about with, the pairing code is the immobiliser PIN, which is on the carpass if you do not know it.
omegafin
Quote from: TheBoy on 24 November 2011, 20:20:59
OK  :y
My pass is lost so I order new tomorrow....
So after pairing display-codes are needed for right speed and fuel consumption ?
Quote from: omegafin on 24 November 2011, 20:55:39
OK  :y
The code index (there is no such thing as display-codes) needs to be correct for your car, engine, gearbox, HIDs, preheater etc, or will report false info.
omegafin
My Omega was in tech programming today.
They managed to program fuel consuption etc and bose display. But cid is still displaying display safe they said that they cant programm it away and shoud take hours to examine the fault and the old  cid should had unpaired first.
The old cid was totally broken so there was no chance to unpair it and the new cid is brand new ie. Never programmed.
Seems that they dont really know how to pair the new cid , as they said thay have never done it and the Service is one of the biggest here ?
Can someone tell the right procedure and tech paths so i can give them the right instructions.
Thanks
Dave DND
Vx should not have any troubles programming in a NEW CID, its only the unpaired ones that they should struggle with.
However, I can probably still retrieve and transfer the data from the broken CID to the New CID if both of them are sent to me
Give me a yell for more info if needed
Radio & Decoding Technician
www.dndservices.co.uk
omegafin
Quote from: Dave DND on 03 January 2012, 10:19:22
Thanks Dave but
I don' have the old cid anymore  :(
I agree that programming should be easy with new cid
Problem is that even they have tech they don't know
how to use it and this problem is not profitable for them.
Is it possible to get the system into safe mode with tech 2 if a component(CID) is missing?
even if the code is present?
Quote from: omegafin on 03 January 2012, 09:41:22
Thanks
Judging by your IP, you are not local to me ;D
If the new CID is in delivery mode, and:
NCDC2013 and CD Changer
or
NCDC2015 and CD Changer and Telematics
were all correctly paired with each other, and to the old, broken CID (and the pairing code is known!!), this is a fairly trivial task that any dealer should be able to do.
If the above conditions are not met, you are in a whole world of pain :(
Dave DND
QuoteProblem is that even they have tech they don't know
If this is a genuine franchised Vx main dealer, then a call to the national Vx customer service is called for and ask them to explain why they are not training the franchised dealers, and why the franchised dealership do not find in financially viable to assist you.
Quote from: Dave DND on 03 January 2012, 11:02:58
Only in this case, it would likely be an Opel dealership ;D
omegafin
Quote from: TheBoy on 03 January 2012, 11:11:37
Yes I live in far far North  :)  so it is Opel . And good point just called GM info and they promised to get it sorted !!
But may take couple of days ...
Dave DND
For the record, any "Franchised" dealership will often get a monumentous rollicking if they are reported to the National / Main Customer service department for failing to assist a customer in this way.
Glad to hear you have made some progress, keep us all informed how you get on.
Quote from: omegafin on 03 January 2012, 11:34:19
Its a trivial task that takes about 2 mins...  ...including getting all the Tech2 out, and waiting for it to start up!
omegafin
I got the call from GM today but not much progress , they said that they don't give any information for Dealers and
it is Dealers duty to ask the information from Germany if they don't know how to do it.
So dealer is now asked to get the right information and then they call me back and then they try programm it again
But seems thet they belive more dealers words than mine :  :'(
Service report was :
"Display safe" sill in display. We can't connet to radio. Radio and display are communicating and likely old dislplay must have reset from radio before changing new and only then radio allows new display to work. We can investigate this problem but it will take more time. First we should find out why we can't connect to the rado.
Is this bullshit, or can radio really be not connectable ?? anyway they managed to programm Bose and consumpiton ?
