Author Topic: help  (Read 1319 times)
micoandmojo
  • midlothian/EDINBURGH
  • burning the midnight oil
    • omega 2.6 auto
help
« on: 25 November 2011, 18:27:29 »
i put my mig in for a mot today, all passed, :D untill the emissions test :( fail co2 through the roof
lamba not even showing, so had cat test done, still showing the same, so whent and got emission cleaner put in tank and drove the car like i stole it, whent back to the mot place and still nothing,
iv'e looked at the engine no pipes blowing all looks ok,but dont know if and when the plugs have been done,or when the car has been serviced.and dont think the cats on the car are naked thay sound allright but lambar sencers dont know much about them :-\ do yous think maybee a good service might help the emissions or what can i do with out spending to much money, can anyone help me, allso my emission light is on to wont go off. ???
Re: help
« Reply #1 on: 25 November 2011, 18:52:11 »
what cleaner did you use? cataclean?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: help
« Reply #2 on: 25 November 2011, 19:10:39 »
The key thing here is your telling us the eml is on , that tells you that you need to get the codes read to find out what the car is complaining about,
Why did you take the car for a test knowing there was an issue with the emmisions, that was a waste of time and money.
Contact H21 up near you for tech 2 session or flash the codes yourself, see the guides section on how to.
Jaguar XJ6
Re: help
« Reply #3 on: 25 November 2011, 20:26:59 »
You need, as Gary says, to read the codes.
Ideally you need to be able to reset them, and see what current issues remain/reappear.
Also check the lambda values are cycling correctly, when the car is fully warm...
micoandmojo
    • omega 2.6 auto
Re: help
« Reply #4 on: 25 November 2011, 20:31:45 »
thanks all for your wisdom ;) i will ned to fined someone to fined the codes and sort them out. thanks again :y
Re: help
« Reply #5 on: 25 November 2011, 22:48:22 »
No need to find any one, you can do the 'pedal trick' on your car ...... http://www.omegaowners.com/forum/index.php?topic=90581.0
 :y :y
Page created in 0.014 seconds with 14 queries.
