Author Topic: WTD rear shocker  (Read 2060 times)
tango
  • brum
WTD rear shocker
« on: 09 December 2011, 15:52:46 »
wanted
driver side rear shocker for 2.6 elite
with self levelling
are they cheap new or is used best option
« Last Edit: 13 December 2011, 10:53:07 by hotel21 »
twiglet
  • Norwich, Norfolk
Re: rear shocker
« Reply #1 on: 09 December 2011, 16:03:57 »
IIRC they are only available from Vxl new, and are £160ish  :o
You may be lucky and find one S/H, but you can never know how long it will last.  :-\
Re: rear shocker
« Reply #2 on: 09 December 2011, 17:29:00 »
Best to replace in pairs if at all possible,although realistically,many people are on a tight budget these days.
tango
  • brum
Re: rear shocker
« Reply #3 on: 09 December 2011, 19:16:25 »
thanks for the replies
"tight budget" definitly
but has any body got any decent second hand or can i put standard shocks in
Re: rear shocker
« Reply #4 on: 09 December 2011, 19:36:05 »
You couldpull he fuse from the self levelling and use standard shocks.Problem then may be that the S/L springs may be too soft,so you need a pair of non S/L springs also.
Re: rear shocker
« Reply #5 on: 09 December 2011, 19:36:37 »
You could pull the fuse from the self levelling and use standard shocks.Problem then may be that the S/L springs may be too soft,so you need a pair of non S/L springs also.
bored bigyin54
  • south wales
    • black beast
Re: rear shocker
« Reply #6 on: 09 December 2011, 20:05:35 »
that was done with mine and it was to soft so put self raising back on
bored bigyin54
  • south wales
    • black beast
Re: rear shocker
« Reply #7 on: 09 December 2011, 20:08:06 »
i think i had the last second hand shocks on here
twiglet
  • Norwich, Norfolk
Re: rear shocker
« Reply #8 on: 09 December 2011, 21:26:09 »
I can probably sort you out with a set of nearly new non-s/l shocks and matched springs if you need them mate.  :y
tango
  • brum
Re: rear shocker
« Reply #9 on: 11 December 2011, 07:52:52 »
thanks for the replies guys
i think ill stick to the self leveling setup
twiglet how much do you want
twiglet
  • Norwich, Norfolk
Re: WTD rear shocker
« Reply #10 on: 12 December 2011, 18:58:09 »
Tango, if you want to stick to the S/L setup, then I can't help you mate.  All the sets I have here are non-S/L.   :(
« Last Edit: 13 December 2011, 10:53:20 by hotel21 »
