Author Topic: codes  (Read 3289 times)
bored bigyin54
  • south wales
    • black beast
codes
« on: 24 December 2011, 12:53:14 »
 ;D can anyone tell me what these codes mean on a 2ltr t reg omega codes are po 130 and po 135  :y
Re: codes
« Reply #1 on: 24 December 2011, 12:59:17 »
You could have tried a basic search  ;)
Its very easy to find!
http://www.omegaowners.com/forum/index.php?topic=90583.0
tango
  • brum
Re: codes
« Reply #2 on: 24 December 2011, 13:13:57 »
p0130  is  02 sensor circuit malfunction ( bank 1 sensor 1)
p0135  is  02 sensor heater circuit malfunction ( bank 1 sensor 1)
Abiton
Re: codes
« Reply #3 on: 24 December 2011, 13:18:58 »
What those codes might mean is that someone has unplugged the lambda sensor, and forgotten to plug it back in.  Or the cable/wiring has been damaged.
Re: codes
« Reply #4 on: 24 December 2011, 13:19:47 »
Easy if you what you're looking for.
Re: codes
« Reply #5 on: 24 December 2011, 13:22:11 »
But he does? He wants codes? So go to the guides > go to the index (second sticky) - Codes link in second post. Dead easy!
bored bigyin54
  • south wales
    • black beast
Re: codes
« Reply #6 on: 24 December 2011, 13:25:29 »
 ;D my mate was told the head gasget has gone by the RAC so he cant work it out  :y
bored bigyin54
  • south wales
    • black beast
Re: codes
« Reply #7 on: 24 December 2011, 14:22:49 »
 ;D he wants to know were these sensors are  :y
Re: codes
« Reply #8 on: 24 December 2011, 14:25:48 »
They are in the exhuast  ;)
Re: codes
« Reply #9 on: 24 December 2011, 14:26:55 »
O2 sensor is another name for a Lambda sensor, as above, they live in the exhaust just after the cat.
Re: codes
« Reply #10 on: 24 December 2011, 14:30:58 »
Its worth checking it is the lamba & not another issue causing this code. You want to really get a live data check done & see what the lamba is doing.
Abiton
Re: codes
« Reply #11 on: 24 December 2011, 16:58:17 »
Lambda sensor on 2.0 -  just before the cat, can't miss it, only thing on the exhaust with wires. Connector not far from the sensor IIRC.
Me
  • Doghouse
  • It was Guffer's fault
Re: codes
« Reply #12 on: 24 December 2011, 18:32:46 »
You mean just in front :P
"Always look on the bright side of Life"
TheNaughtyBoy
Re: codes
« Reply #13 on: 24 December 2011, 18:54:27 »
I was looking from the other end of the exhaust!  ;) ;) ;)
I noticed my mistake .................. hoped no body else would  ::)
Re: codes
« Reply #14 on: 24 December 2011, 18:55:39 »
I played it safe & just said on the exhaust, as was going to be a 50/50 guess  ;D
