Author Topic: Fault Codes please  (Read 1374 times)
moose
  • SWINDON WILTS
Fault Codes please
« on: 02 January 2012, 17:27:00 »
Hi all.
Got the warning light coming on sometimes when starting (car with spanner) and the engine cuts out,pedal trick shows 1613 and 1612.Any ideas please 2001 2.6 MV6 ::)
Thanks guys if its a sensor can you please also tell me where it is !!!
hotel21
  • The Kingdom of Fife
Welung666
Re: Fault Codes please
« Reply #2 on: 02 January 2012, 17:44:44 »
Those are both immobiliser codes. You need to check the transporter in the key is secure and the immobiliser ecu is properly plugged in around the ignition barrel.
moose
  • SWINDON WILTS
« Reply #3 on: 02 January 2012, 18:02:47 »
Thanks guys i`ve been having trouble with the connections in the key ,,got a piece of card in there to keep it tight , maybe this was the problem.
I will use the spare key for now and see if it happens again.
thanks again all,
Marcus.
