Author Topic: In bits  (Read 16137 times)
In bits
« on: 08 January 2012, 19:24:12 »
What started out as just a replacement rad had turned out to be a bit more in depth  ::)
HBV valve done but then i had to replace the rad/then the condenser was falling to bits  :o
First off as well was the anti roll bar bushes..under the gold paint .
Got rid of some weight and junked the condenser and fans ...quite heavy these items
Now plenty of room to gain access to the aux belt and next on the list ...cambelt  ::)
Re: In bits
« Reply #1 on: 08 January 2012, 19:26:57 »
Those 2 fans in front are the cooling fans...  ...best ensure they go back in ;D
twiglet
  • Norwich, Norfolk
Re: In bits
« Reply #2 on: 08 January 2012, 19:28:08 »
Took the words right out of my mouth!!  ;D
Re: In bits
« Reply #3 on: 08 January 2012, 19:33:49 »
Whats the fan at the back of the main rad for then ?
Just as well there easy enough to get back in  ;D
Cant work out why there is 3 fans ...i thought these 2 were for the condenser ?
« Last Edit: 08 January 2012, 19:37:31 by eatmydust »
Re: In bits
« Reply #4 on: 08 January 2012, 19:45:35 »
3 cooling fans ? I guess this is normal ???????
Re: In bits
« Reply #5 on: 08 January 2012, 20:46:36 »
Anyone ?   ?   ?   ?   ?
Re: In bits
« Reply #6 on: 08 January 2012, 21:55:09 »
Anyone ?   ?   ?   ?   ?
Yes, all three are used for engine cooling it required.  :y :y
Re: In bits
« Reply #7 on: 08 January 2012, 22:02:44 »
Ok thanks andy , no hassle to replace them i just thought they were for the air con rad only so i was going to leave them off as ive done away with the air con .
Cheers  :y
X3 OXE
  • Reading, Berkshire
  • Sir Sideways
    • 245bhp 3.1 manual MV6
    • Omega Owners Network
Re: In bits
« Reply #8 on: 25 January 2012, 20:00:52 »
funny topic,..
Keep them off mate, They are aircon rad fans, which also helps air get through to the main rad fan.
If youve removed the aircon and rad, then you need to remove these too as they are not needed. the main rad has its own fan.
Jason.
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Re: In bits
« Reply #9 on: 25 January 2012, 20:04:22 »
funny topic,..
Bang on the money with no aircon you dont need the aircon fans  :y
Darren
VX1
Re: In bits
« Reply #10 on: 25 January 2012, 20:18:16 »
I have had my air con rads removed now for two years without any issue's, as said if you have removed your aircon then you can keep the aircon rads off but upto you.
Vx Trade club card holder
Halfords trade card holder
X3 OXE
  • Sir Sideways
Re: In bits
« Reply #11 on: 25 January 2012, 20:30:17 »
The aircon rad and fans restrict airflow to the main rad, which is why omega v6's run so hot all the time, Removing the aircon rad and fans is one of the best mods you can do, Engine temps are perfect after this and run nice and cool.
Mines been done for a couple years too, along with my brothers, dads and everyone else i know with omega's have done the same.
Keep them off and youll see for yourself  ;)
Jason.
Re: In bits
« Reply #12 on: 25 January 2012, 20:35:53 »
Well i never  :o :o :o :o :o    im going to rip them out now , i had to make a make shift bar to hold the air con rad fans hold up as the rubber grometts were shot . I did wonder why these 2 fans were needed without my air condenser  ::) aid cooling it will ...nice to know you have done this mod and passed on the info  :y :y :y :y
Corrado1441
  • N.Ireland
    • Vauxhall Omega Elite
Re: In bits
« Reply #13 on: 25 January 2012, 20:36:13 »
But it might get warm outside and you will need your Aircon  ;D
dazzerM
  • Reading
Re: In bits
« Reply #14 on: 25 January 2012, 20:41:06 »
Just open the window  ;D ;D
It never gets that warm in the UK  :D
Darren
