Author Topic: cruise control fittment on pre facelift  (Read 5146 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 09 January 2012, 17:29:03 »
I finally got round to fitting the cruise on my facelive mv6 3.0 today
(followed guide from forum)
fitted the stalk / brake switch (4 pin) with no prob but had trouble fitting the actuator
due to fittement of lpg
I had a man fit it - just under/side of air box and all connected up but
cruise does not work
have check fuse 15 is working as all other electrical items on fuse work
one thing I noticed was that the wiring loom is quite tight/stretched
when connected to actuator
any ideas?
ken
Re: cruise control fittment on pre facelift
« Reply #1 on: 09 January 2012, 17:47:11 »
any ideas?
ken
What`s the bowden cable like re; slackness, two different lengths for the V6`s
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #2 on: 09 January 2012, 18:05:35 »
Is that due to the extended plenum in some cases?
Also, does FL need Tech 2 or is that only if DBW?
« Reply #3 on: 09 January 2012, 18:26:23 »
Is that due to the extended plenum in some cases? Yep
idwal
« Reply #4 on: 09 January 2012, 18:32:32 »
How would I know which cable length I need? ???
My car has a throttle cable - not drive by wire
So I have fitted pre-face lift cruise
Ken
idwal
« Reply #5 on: 09 January 2012, 18:34:30 »
The cable is same as throttle cable!
Ken
« Reply #6 on: 09 January 2012, 18:39:40 »
Ken
Bowden cable (which actuates the cruise) is not the same as the throttle cable ???
idwal
« Reply #7 on: 09 January 2012, 18:47:33 »
Can I take it that the Bowden cable
Is the cable that comes out of the
Actuator
If so the tension on the cable is about
Was a little slack until I used a cable tie
To reposition cable
Ken
« Reply #8 on: 09 January 2012, 19:09:39 »
Actuator
To reposition cable
Ken
Yep. I suggest you doublecheck that the elec. conn. and wiring hasn`t been damaged due to it being overstretched and make sure the Bowden cable inside the casing isn`t being restricted by the fitting of a cable tie
idwal
« Reply #9 on: 09 January 2012, 19:27:25 »
Thanks for ur help
Cable movement seems ok
Not notchy but will check out cable
I bought the kit from the forum about 14 months ago
So is there a way to check that I got the one with the correct
Length cable
Ken
idwal
« Reply #10 on: 09 January 2012, 19:30:45 »
Correction to last statement
I will check out the electrical connection
To the actuator
jordan681
  • Sc unthorpe, North Lincs
    • Irmscher 3.0 MV6
« Reply #11 on: 09 January 2012, 19:45:29 »
Your miggy is the same year and model as mine, and i have retro fitted cruise control..  I had to get the C/C activated(via on board computer) with a Tech 2..  so I think a trip to your local VX garage or maybe someone on here that can do it for you..
Always looking for a bargin..  PM me if u have any uprated Miggy parts...
« Reply #12 on: 09 January 2012, 19:47:27 »
Shouldn`t need TechII on a 3.0ltr facelift or not
jordan681
    • Irmscher 3.0 MV6
« Reply #13 on: 09 January 2012, 19:53:52 »
Unfortuatley they do Rob, on the 3.2, 2.6 and the Diesel already have the C/C activated (the DBW) models..  I made the same mistake, and it was someone on here that told me to get the C/C activated.  it also says on the fitting guides in the maintainence section that a Tech 2 is required.
« Reply #14 on: 09 January 2012, 19:59:30 »
No they don`t
