Author Topic: cruise control fittment on pre facelift  (Read 5148 times)
Re: cruise control fittment on pre facelift
« Reply #15 on: 09 January 2012, 20:02:59 »
What`s the bowden cable like re; slackness, two different lengths for the V6`s
Is that due to the extended plenum in some cases?
Also, does FL need Tech 2 or is that only if DBW?
Your miggy is the same year and model as mine, and i have retro fitted cruise control..  I had to get the C/C activated(via on board computer) with a Tech 2..  so I think a trip to your local VX garage or maybe someone on here that can do it for you..
Shouldn`t need TechII on a 3.0ltr facelift or not
Unfortuatley they do Rob, on the 3.2, 2.6 and the Diesel already have the C/C activated (the DBW) models..  I made the same mistake, and it was someone on here that told me to get the C/C activated.  it also says on the fitting guides in the maintainence section that a Tech 2 is required.
No they don`t
If you`re fitting cruise to a 2.5 or 3.0, irrespective of whether it`s a facelift or not, this is the guide you use & no TechII
http://www.omegaowners.com/forum/index.php?topic=90533.0
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« Reply #16 on: 09 January 2012, 21:01:36 »
.   Quote from: RobG on Today at 19:59:30
Quote from: jordan681 on Today at 19:53:52
Quote from: RobG on Today at 19:47:27
Quote from: jordan681 on Today at 19:45:29
Quote from: jonny2112 on Today at 18:05:35
Quote from: RobG on Today at 17:47:11
No they don`t
That was the guide I followed
But can anyone tell me how to recognise
The correct length cable
Is there a serial no  ect
Ken
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #17 on: 09 January 2012, 21:33:27 »
Mine came from a 2.5, but how big an issue was the lpg? Were you able to use the correct mounting position?
idwal
« Reply #18 on: 09 January 2012, 21:58:52 »
No,     I had LPG fitted and they fitted some parts there
It is located in gap just below air box screwed to the wheel
Arch - and rotated 90 degrees so cable points
To steering wheel
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #19 on: 09 January 2012, 22:04:41 »
I was just wondering if the positioning was affecting the 'length' of the cable. The mounting points dictate the correct placement  :-\
idwal
« Reply #20 on: 09 January 2012, 22:36:32 »
Without have another car too compare against
Or a better picture of routing of cable it is difficult        too say
And also the fact I am a mechanical novice
Ken
Bob G
  • Gloucester
« Reply #21 on: 09 January 2012, 22:38:39 »
I fitted cruise to my 2.0 and had the same problem with the LPG, they had located the ECU for LPG where cruise goes.  Solution moved the LPG bits as the cable run was sufficient and fitted cruise inot its correct location
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #22 on: 09 January 2012, 22:44:02 »
Is there any way the lpg unit can be dislodged temporarily? To allow the cruise module to be mounted correctly to at least rule that issue out?
idwal
« Reply #23 on: 10 January 2012, 02:18:04 »
Not enough room on LPG pipes ect and would be
Worried about leaks ect
That was why cruise was placed where it is now
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #24 on: 10 January 2012, 08:59:34 »
That's what I thought. It was just an option so you could decide whether it was a faulty module or more down to the positioning.
idwal
« Reply #25 on: 10 January 2012, 12:01:04 »
Is there anyway to test the actuator apart from driving the car
I am dubious of loosening or moving the lpg parts if I have to then drive the
car too test the cruise control!
ken
Bob G
  • Gloucester
« Reply #26 on: 10 January 2012, 16:36:45 »
Having said that when I fitted mine all seemed to be correct but it would not work, thanks to info on here suspect was indicated as brake switch, I thought I was lucky as i had the correct 4 pin switch factory fitted, anyway changes it and success.  So it could be one of several items
idwal
« Reply #27 on: 14 January 2012, 17:35:02 »
well - I fitted a new brake switch today and the cruise works fine :y
thanks too all of you who posted replys, I just glad it all works now  ;D
thanks
ken
RobseyMV6
  • west sussex
« Reply #28 on: 14 January 2012, 20:41:01 »
thanks
ken
All sounds good  :y
enjoy the lazy life  ;)
Page created in 0.032 seconds with 16 queries.
