Author Topic: Engine Protection/Oil Drip tray  (Read 2213 times)
ScaniaV8
  • Luton, Bedfordshire
« on: 11 January 2012, 10:14:45 »
Could anyone please advise whether this tray was a standard fitment to early Omega B models or just fitted to certain model specifications. I have seen reference to it into various maintenance manuals etc., but my current Omega does not seem to have one fitted. Not sure whether it has been removed by previous owners(s).
thanks
Re: Engine Protection/Oil Drip tray
« Reply #1 on: 11 January 2012, 11:25:08 »
Standard to all I believe.
And Aids cooling more than you would think :y
« Reply #2 on: 11 January 2012, 11:35:44 »
As JB says, fitted across the range and obviously removed for whatever reason
ScaniaV8
« Reply #3 on: 11 January 2012, 13:54:04 »
Appreciate if someone could post a picture of one of these trays in situ so I can see what this tray looks like and also how is it attached (bolts /screws/ brackets ( etc etc).
thanks in advance.
« Reply #4 on: 11 January 2012, 15:15:09 »
Open the bonnet and look down between the front of the engine and the radiator. If you can see the ground you haven't got one. ;)
« Reply #5 on: 11 January 2012, 16:19:47 »
thanks in advance.
4 or 5 IIRC
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 11 January 2012, 18:59:51 »
4 bolt headed screws hold the tray on Scania V8 :y
Like already said it helps with cooling, the cool air is kept inside the engine bay then channeled down the gearbox tunnel instead of escaping under the engine :y
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
« Reply #7 on: 11 January 2012, 19:11:02 »
You will more than likely find that at somepoint someone has unwittingly snapped one of the bolts and not bothered to drill it out
Thats what had happned on mine and the effect on cooling was noticble once it had been replaced  :y
Darren
twiglet
  • Norwich, Norfolk
« Reply #8 on: 11 January 2012, 19:25:14 »
I've got a couple in the shed if you need one mate.  :y
« Reply #9 on: 11 January 2012, 19:57:13 »
All assuming petrol. Diesel ones are much bigger, and weigh about 8 tonnes...
Project TB2's is still in the loft of the garage I believe. Opps.
