Author Topic: My Car has started beeping!  (Read 1873 times)
Daz1111
  • Norwich
« on: 12 January 2012, 20:41:36 »
This is a really weird one!  :-\
My 2.2DTi Est (02 plate) has started to emit 3 beeps from the off side of the engine bay when the ignition is turned off. I have had the car for 18mths and it has never happened until 2 weeks ago. It doesn't happen every time, only about 50% of the time.
Has anyone got the faintest idea what it is? ???
Re: My Car has started beeping!
« Reply #1 on: 12 January 2012, 20:46:13 »
Powersounder batteries failing. Beeps are a warning of possible self-combustion. Remove & bin. Replace with new to keep the factory specced alarm
http://www.omegaowners.com/forum/index.php?topic=90675.0
Daz1111
  • Norwich
« Reply #2 on: 12 January 2012, 20:56:57 »
Does the Power Sounder have batteries in it that can be replaced or does the whole unit need changing? ???
Sorry for being a bit of a dunce - have never liked the electrical stuff!  :(
martin42
« Reply #3 on: 12 January 2012, 20:58:52 »
buy a new unit,circuit board will most probably be damaged from where batteries have leaked :y
Daz1111
  • Norwich
« Reply #4 on: 12 January 2012, 21:13:00 »
Cool Thanks! ;D
pauls
  • By the sea minehead
    • Bmw x3
« Reply #5 on: 12 January 2012, 22:23:54 »
Take the old one out asap
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 12 January 2012, 22:25:50 »
Yup, all seen photos on here of horror stories.  :'(
RIP Paul Lovejoy
« Reply #7 on: 12 January 2012, 22:29:51 »
Thats a bit grim.
As others suggest, remove powersounder, let Norfolk County Council bury it in landfill.  Up to you if you replace it. Most don't ;)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #8 on: 14 January 2012, 10:31:20 »
If it's only bleeping then the chances are the batteries haven't leaked yet.
They can be replaced but from your humble confession ;) you may not want to take that on.  They are not designed to be replaced.  Also, the fire hazard may well be due to inadequate protection in the form of a fuse.  I would be inclined to add an in-line fuse if I were replacing the batteries.  It would be internal to the unit and somewhere around the 1amp rating at a guess.
Land-fill isn't the best place for the old unit as it contains cadmium amongst other nasties, but the alternatives are not necessarily simple.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
