Author Topic: Police MV6 LSD thumping??  (Read 4536 times)
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« on: 19 January 2012, 22:08:58 »
when my car is cold all fine,
(well except for headlight & suspension issues but there in other posts please view if you can help...)
After about 30mins of hard use or light 60mph cruse up motorway over 20/30miles the car after i stop then feels like i have 2 flat rear tyres feels like a thudd from 1st & 2nd gear from the back of the car?? some times doesnt happen like my last trip from worcester to leeds no probz but even after a 7mile drive threw lanes to malvern was enuf that when i stopped at junction started doing it again just really odd... any ideas?? it has covered 220.000 police miles 17.000 private & ive had it for last 3000miles giving it a right kicking but it was doing it day i picked it up.....
ive got 2ltrs of LSD spec oil for it any idea how much it needs....
could it be low on oil or any other issues??
because when i do drift her around sometimes both wheels drift nicely but next roundabout then 1 wheel will light up??? but when it does that its not thudding either...??
roberts_1409
  • Lincoln
    • Vectra and Omega
Re: Police MV6 LSD thumping??
« Reply #1 on: 19 January 2012, 22:20:44 »
You got any backlash or lift in the diff input shaft?
Zippy2012
  • Worcester uk
« Reply #2 on: 19 January 2012, 22:25:39 »
All feels quite tight but i check it tho... odd that it only does it when its hot in 1st 2nd & reverse?? but main issue atmo is suspension  :(
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #3 on: 19 January 2012, 22:31:23 »
Wierd  :-\  Auto or manual?
Zippy2012
  • Worcester uk
« Reply #4 on: 19 January 2012, 22:46:35 »
Manual with police spec 2.5td wide ratio box
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #5 on: 19 January 2012, 22:59:33 »
All I can think of is if the clutch release bearing is knackered or if one or more of the springs on the clutch pressure plate has weakened or snapped and sending the shock down the propshaft, unless my 1st idea in that you have a prob with ur diff.
Other than that, I dont know
Zippy2012
  • Worcester uk
« Reply #6 on: 19 January 2012, 23:05:48 »
 :-\ ummm i ask the question but really odd why only in 1st 2nd revese & not 3rd 4th 5th??? sumone said the lsd may be snatch plates that could be grabbing when not needed or shuddering /slipping &maybe new oil would cure it?? ant idea how much oil in a rear diff??
« Reply #7 on: 19 January 2012, 23:18:57 »
Might be worth sending a PM to 2Woody. He knows about LSD,s including rebuilding them. If its done over 200,000 miles, mostly in police duty, it wont have much life left in it imo.
Lower gears will put more force through the transmission.Higher gears less so,as the car already has  built up its own momentum.
« Last Edit: 19 January 2012, 23:20:59 by Albs »
Zippy2012
  • Worcester uk
« Reply #8 on: 19 January 2012, 23:23:32 »
i get hang of this site soon  ;) i try find 2woody & ask the question cheers! only good thing about car is had a £4200 brand new 3.0MV6 engine fitted 4000miles before old bill sold it! its done only 20.000miles on new lump! shame they didnt look after everything else!!
2woody
  • Northumberland
« Reply #9 on: 20 January 2012, 09:10:29 »
I'd try to establish if it has LSD first. There are people on here who can decode the VIN and tell you...
« Reply #10 on: 20 January 2012, 09:12:59 »
aye, pm me your reg (& vin if handy, may or may not need it) and ill look up its factory spec :y
2woody
  • Northumberland
« Reply #11 on: 20 January 2012, 09:16:20 »
see look - we're a nice bunch on here.....
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #12 on: 21 January 2012, 19:05:22 »
Every LSD Mig Ive driven gives a slight thud or thump under certain pull away conditions or gearbox drops, even low mileage ones, nothing major though, but not to sure how bad yours is doing it. As for your other issues, probably best to start with an oil change, not sure what LSD oil you have, but from empty fill up with a litre (From memory) of Fuchs BOA90 then top up with normal VX diff oil, putting too much LSD oil in can make the plates too slippery.
Good luck with it.
Chris.
Zippy2012
  • Worcester uk
« Reply #13 on: 22 January 2012, 00:42:33 »
Good luck with it.
Chris.
Alright Chris, ive bought 2ltrs of Carlube EP75 W90 Hypoid gear oil fully synthetic (spec API GL-4,GL5 ,ZF TE MLO5A) & States on back including limited slip diffs so hopefully it be ok...???
According to the spec sheet it has an lsd & once jacked up both spin if i spin 1 wheel,
unlike my cdx which 1 went clock 1 anti clock so defo has one,
Car drives fine but odd shudder & thudding like 2 flat tyres from a standing start in 1st reverse & sometimes into 2nd gear... but not all the time intermitant... car drifts lovely spinning both wheels but now & again only spins inside tyre closest to bend... maybe once oil changed it will sort it i hope... Hopefully meet up in the future somewhere...
zirk
  • Epping Forest
« Reply #14 on: 22 January 2012, 23:48:34 »
cannot comment on the Carlube stuff, sounds like normal gear oil to me, reckon your still need an LSD addertive, still reckon an oil change is in order (220K)?
As for the shuddering, thinking out loud now, starting to think axle oscillation when the LSD kicks in, hows the rear suspension set up, worn or loose, or furbed bushes at the rear?, probably wont happen at higher speeds and high speed gear changes. :-\ :-\
« Last Edit: 23 January 2012, 00:02:46 by zirk »
