Author Topic: N/S Xenon goes out while driving...!  (Read 1925 times)
sjl264
  • stoke on trent
    • 2.6 cdx silver
« on: 20 January 2012, 11:52:48 »
Hello all.
My 2.6 CDX has a strange fault the N/S Xenon goes out after being on for approx 10 mins of driving and flickers before it goes out. Error message on dash comes up Headlight/Tail light and the little check logo is lit. Turn the engine off and all lights, switch everything back on and on it comes.
Doesn't always do it and i have sprayed the connectors with a moisture dispersant and this seem to help for a while but the fault is back again.
Ballast pack? Xenon filament? Anyone had this? i would appreciate any help i am spanner efficient but don't want to disturb anything yet.
Thanks ;)
    • E250 Est / Elroq
Re: N/S Xenon goes out while driving...!
« Reply #1 on: 20 January 2012, 12:12:10 »
any history?  bulbs ever been changed?
its a bit unusual..
Id maybe swap bulbs side to side, see if the problem moves,
then the same with ballast if necessary.
That should help pinpoint the issue.
sjl264
  • stoke on trent
    • 2.6 cdx silver
« Reply #2 on: 20 January 2012, 12:25:48 »
Thanks for the swift reply.
No bulb changes since i have owned it.
Do i have to take the headlights out to get to the ballast packs as the n/s it tight for hand space, I understand that they are underneath the pods. :y
« Reply #3 on: 20 January 2012, 12:38:39 »
Yep, lot easier
sjl264
  • stoke on trent
    • 2.6 cdx silver
« Reply #4 on: 20 January 2012, 12:49:18 »
Thanks, i will have a go this weekend and let you know. ;)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #5 on: 20 January 2012, 13:25:37 »
MAKE SURE you follow the headlight removal guide, especially so you don't miss the hidden front screw.
sjl264
  • stoke on trent
    • 2.6 cdx silver
« Reply #6 on: 20 January 2012, 14:13:25 »
Top guide action..... :D  just had a read and loving the work. :y
