Author Topic: Mot Repairs And few other bits  (Read 1523 times)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« on: 23 January 2012, 20:10:27 »
Evening all hope all I'd well in land of OOF!!! ::)
I've just had my MOT Failure and all 4 bushes have failed on the front the two rear shockers need replacing and a tyre so not too bad (£171.56)
Also my rocker cover gaskets need replacing
Also I am having problems with coolant loss after 2-3 days no leaks visible but when I put coolant in it will last for a day or two then leak from above GBOX and empty the tank again and am stuck as to what it is the HBV was done last year just put new plugs in.
Also gearbox seams to hold gears every now and then turn engine off and back on and it's fine
When I changed the plugs there was cup fulls of oil in plug 6/4/3/1 have cleared that out
The reason I'm telling you all this is I am asking for some help From a local OOF member please I need help
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
Re: Mot Repairs And few other bits
« Reply #1 on: 23 January 2012, 21:12:36 »
Classic symptoms of failed cam cover gaskets, make sure who ever does it use genuin vx parts (including the grout) and do both sides at the same time.
As for the coolant leak check around the hbv again, get a good torch and see if you can find any dried or even wet coolant the try and see where the source is. The shocks should be too shocking ( ;D ) as I'm guessing there the normal ones and not s/l ones.
07 Volvo V70 T5 SE ex police
Elite_L0ver
  • On too Omega #2
« Reply #2 on: 23 January 2012, 21:18:24 »
I wanted to do the work myself and just wondered if anyone wanted to help coz I'm unsure espicallyThe rocker gaskets or is there a tutorial on here or anywhere that would help me
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 23 January 2012, 21:50:28 »
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #4 on: 23 January 2012, 21:52:20 »
Pretty much every guide you could need is in the Maintenance Section. Why not give it a go and save some dosh at the same time. If you don't do it right they'll still need doing so nought to lose IMO :y
RIP Paul Lovejoy
tidla
  • solihull
« Reply #5 on: 23 January 2012, 23:01:19 »
after the hbv valve in my case came the oil cooler plate. leaks show on the gearbox and the front sump.
