Pages: [1] 2 3  All   Go Down
Author Topic: winter home for homeless cats..  (Read 3624 times)
« on: 26 January 2012, 19:36:21 »
As I mentioned in another thread that I had built several cat houses for winter, I thought it would be useful for some who like cats ..
its impossible to take every street cat in home so you may build a house easily/cheaply that can protect them from cold
winter ( up to -20 celcius, not tested for lower temps)..  one important point , place them on higher places that dogs cant reach
and door away from wind direction.. (if there is too much rain you can cover it with extra nylon if you wish)
I use wood nails (or metal nails if you prefer ) about 8-9 cms long to fix the parts..
and use hot silicone to glue together also for added insulation on all connections..
general material used is 4 cms thick rigid home insulation foam (better quality not the ordinary foam) panels..  the only problem is they are not easy to cut and need a sharp short knife.. also a long ruler (at least 50 CM or longer) and a CD pen..
and lastly some soft rubber foam to be used as a bed..
(without front panel) 2 level design higher part will be more hot obviously
Re: winter home for homeless cats..
« Reply #1 on: 26 January 2012, 19:36:42 »
as you can see there is a small window covered by nylon from both sides for some light inside  (but must glued properly or all hot air will leak outside)
 and a scotch towel for the door vertically cut for cats to enter-exit easily
« Last Edit: 26 January 2012, 19:42:01 by cem »
« Reply #2 on: 26 January 2012, 19:37:11 »
 and the dimensions (sorry for the drawing done in paintbrush quickly)
cleggy
« Reply #3 on: 26 January 2012, 19:41:57 »
A friend of mine runs a charity looking after feral cats in Spain  :y
http://www.mamacat.co.uk/
« Reply #4 on: 26 January 2012, 19:43:41 »
I'm glad to see more people care for homeless cats.. :y
« Reply #5 on: 26 January 2012, 20:03:26 »
You soft sod cem! ;D
I will have to show this thread to Mrs TheBoy, as she is cat mad as well :y
« Reply #6 on: 26 January 2012, 20:07:34 »
Good thinking. :y With this we could relegate our cat to the bottom of the garden where it won't be a PITA.*
*- Personally, I would relegate it a bit further down the garden to the Watercress line, just in front of a train. :-X
« Reply #7 on: 26 January 2012, 20:10:29 »
Mrs KevinWood will be chopping off your nads and boiling them if she knew.... ;D
« Reply #8 on: 26 January 2012, 20:15:19 »
Warms the cockles to see someone so caring Cem.Despite what you read on here,generally speaking the British care more for animals than they do for people. ;D :y
« Reply #9 on: 26 January 2012, 20:16:20 »
cem - the mad cat woman Mrs TheBoy approves, and loves your moggies. Kevin Wood, Mrs TheBoy is going to kill you when she sees you ;D
« Reply #10 on: 26 January 2012, 20:17:11 »
Mrs TB just said something similar ;D
« Reply #11 on: 26 January 2012, 20:23:03 »
 yep.. I accept I have a soft heart :) but I love them :y
« Reply #12 on: 26 January 2012, 20:24:42 »
Thanks :y
« Reply #13 on: 26 January 2012, 20:26:09 »
I knew that a part of me is British ;D :y
honestly they are so hopeless without us :-\
« Reply #14 on: 26 January 2012, 20:27:52 »
please send my best wishes to her :y
Pages: [1] 2 3  All   Go Up
