Author Topic: heated seat pad replacement and rear window switch....  (Read 1378 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 01 February 2012, 23:54:00 »
is there a how to for the front and rear seat heater pads?
thanks
alex
V8!!!!
Re: heated seat pad replacement and rear window switch....
« Reply #1 on: 02 February 2012, 08:49:31 »
There are no pads as such in Elite leather,if that's what you have?
The element is placed over the leather and glued in with a pad glued over the top. It's a case of repair by cutting in through the pad, then re solder the wires if it's the element that's failed.
If theres no obvious sign of damage to  the leather by scorching, or all the circuits bell out, then chances are the control unit has filed which is tucked up in the base on the outboard side and can be easily accessed by unclipping the base leather then lifting the foam. This controll unit needs to be replaced to get the seat working again.
ngrainqey
  • rotherham
« Reply #2 on: 02 February 2012, 08:52:42 »
thanks for the informative reply chris!
is that just for the front seats on the elite with the control unit as drivers seat isnt working and also rear passenger- rear drivers side works
thanks
alex
V8!!!!
« Reply #3 on: 02 February 2012, 09:03:05 »
Yep, front seats only as they are adjustable for temp settings.
Rears are easier as there is just an on off switch. I don't see any reason for a control box, but then I am hopeless with electrics. ;D
« Reply #4 on: 02 February 2012, 09:16:12 »
thanks
alex
This might help
http://www.omegaowners.com/forum/index.php?topic=98495.0
and this is for cloth seats
http://www.omegaowners.com/forum/index.php?topic=90569.0
« Reply #5 on: 02 February 2012, 12:00:23 »
I have a lead here with switch made by Lincs Robert for testing seats out of the car if you need to borrow it? It has the plug to seats and dash switch. Just add battery power and away you go.
ngrainqey
  • rotherham
« Reply #6 on: 02 February 2012, 16:42:37 »
you can do chris yes  :y
let me know what you want for postage and i can paypal it you
thanks
alex
p.s thanks for the link rob but i had a nosey, just wondered with it being elite
V8!!!!
« Reply #7 on: 02 February 2012, 16:58:23 »
Don't worry about the postage, but on the absolute proviso that you guarantee to forward it back to either me,LincsRobert, or who ever else needs it next....?
Pm me your address. :)
