Author Topic: cutting out  (Read 3287 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
cutting out
« on: 13 February 2012, 16:51:05 »
Going to look to see if there are any error/fault codes later but in the mean time just thought someone might have a quick idea of areas to look at.
I really think it's a fuel problem and a clean of the carb might solve it, but at the moment it will sit when started ok on tick over, after a few miles and it's warmed up it sometimes just cuts out when you decelerate as the revs drop and suddenly you have a heavy steering wheel and brakes!
It starts straight away no coughing or spluttering.
Why I think it's a fuel problem;
Due to lack of funds we let the car run to a range of 8miles, we eventually fuelled it with £10 the range stayed at 8miles and dropped to 0, only after filling with over £20 did the needle move.
The fuel filter was changed last July(2011), but since it was left to run on fumes the problem has occured and not gone away.
My wife is is not happy to drive it as it cuts out just as your pulling off.
Other bits to note;
When parked on our sloping drive nose down in -deg temp it coughs splutters and cuts out, it nose of car is up when starting it is perfectly fine.
I realise this has become a rather complicated question...  :P
www.impactcls.co.uk - Flight Case Manufacture
Re: cutting out
« Reply #1 on: 13 February 2012, 17:04:03 »
It does seem to point to the fuel filter becoming partly blocked by tank bottom debris :-\
Re: cutting out
« Reply #2 on: 13 February 2012, 17:07:48 »
Other bits to note;
There's your problem Pete ::) ;D
Impact Pete
  • Derby
Re: cutting out
« Reply #3 on: 13 February 2012, 17:17:12 »
Other bits to note;
A clean up with the carb cleaner
Re: cutting out
« Reply #4 on: 13 February 2012, 18:28:06 »
Any clues as to what engine?
Re: cutting out
« Reply #5 on: 13 February 2012, 19:48:43 »
Other bits to note;
If its got a carb fitted it won't run too well ;)
  • Auckland
    • Mazda MPV
Re: cutting out
« Reply #6 on: 13 February 2012, 20:24:36 »
If it is still the same car these threads point to it being a facelift V6
http://www.omegaowners.com/forum/index.php?topic=82226.msg1080386#msg1080386
http://www.omegaowners.com/forum/index.php?topic=76450.msg1027664#msg1027664
They also refer to a MAF problem. Was it fixed? Was a genuine MAF fitted?
Would be easier for people to offer useful advice if you updated your profile with your car details :y
Impact Pete
  • Derby
Re: cutting out
« Reply #7 on: 13 February 2012, 21:48:27 »
1. where has my profile info gone! the car info was there when I signed up a few years ago, is this something to do with the new website?
I also have to put a _ in my log in name now which took me ages to figure out when I tried to log in when the site was changed.
Its a V6 2.6 Elite, and it's not the MAF
Impact Pete
  • Derby
Re: cutting out
« Reply #8 on: 14 February 2012, 08:55:18 »
Ok after wierdly having to add all my profile info back into my profile  >:(
I have redone the pedal trick and other than a transmission service request 1700 there are missfires on all but cylinder 6.
Impact Pete
  • Derby
Re: cutting out
« Reply #9 on: 14 February 2012, 08:57:02 »
Other bits to note;
Pete, I should of maybe made my self clearer, I was going to clean out the breathers and throttle body etc with the carb cleaner as when I did this in the summer it ran like a dream so I thought trying that might be the answer.
hope that explains the carb bit for you :)
Re: cutting out
« Reply #10 on: 14 February 2012, 08:57:45 »
Which could be attributed to a fuel starvation problem as you have suggested ;)
May be worth swapping the fuel filter first :-\
Re: cutting out
« Reply #11 on: 14 February 2012, 18:49:30 »
Car data didn't survive the software change last September.  If its lost it since September, I need to know.
We couldn't possibly manually enter the details for 10,000 members ;)
Impact Pete
  • Derby
Re: cutting out
« Reply #12 on: 14 February 2012, 20:16:21 »
Hi no worries I just had not noticed, it did take along time to realise I now havve to put a '_' between impact and pete when logging on! I thought I had been banned!  :P
Re: cutting out
« Reply #13 on: 14 February 2012, 21:24:52 »
The old software allowed login with either your Login ID or your Displayed Name, this software insists on Login ID only.  There is a big message at top when you log in ;D ;D ;D
That is the trouble when you move to significantly different software, as each has its little unique advantages and disadvantages.
Impact Pete
  • Derby
Re: cutting out
« Reply #14 on: 21 February 2012, 16:00:08 »
Ok, spent afternoon taking plenum off cleaning breathers thoughrally and all that, only been a year since I last did that anyway, there are no signs of oil and it was pretty clean so the long shot was incorrect, it has been running on a fullish tank of petrol and still cuts out when revs drop so not sure it is petrol problem.
All points maybe to MAF again? but this was replaced in July 2011, no codes either just missfire codes.
It only happens 1 in every 4 times of deceleration etc.
So should I un plug the MAF and run it for awile to confirm or does anyone have a brain wave?  :-\
Page created in 0.025 seconds with 16 queries.
