Author Topic: cutting out  (Read 3286 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
Re: cutting out
« Reply #15 on: 21 February 2012, 19:24:20 »
Confussed.  ???
I unplugged the MAF started her up drove down the road and the car is like a rocket, MPG good to, no cutting out.
I thought the MAF unplugged would cause car to run with no power?
www.impactcls.co.uk - Flight Case Manufacture
markspark
  • Bolton
Re: cutting out
« Reply #16 on: 21 February 2012, 19:57:48 »
We couldn't possibly manually enter the details for 10,000 members ;)
[/quote]
Does this mean you have something better to be doing  ;D ;D
Andy H
  • Auckland
    • Mazda MPV
Re: cutting out
« Reply #17 on: 22 February 2012, 21:05:24 »
Confussed.  ???
With the MAF unplugged the ECU goes into 'limp home mode' & uses a default map. It should run even better with a good MAF :y
To be absolutely certain that the MAF is guilty you need to get the live readings read by someone with Tech2 or a good code reader.
Did you fit a genuine MAF last time?
Impact Pete
  • Derby
Re: cutting out
« Reply #18 on: 22 February 2012, 21:56:29 »
Confussed.  ???
All sorted now thanks, with the MAF unplugged it did not revert to limp home mode, I have had that a few times it's like pulling off with one cylinder firing.
The car is spot on with it unplugged so when my GM MAF arrives I will look forward to what people are saying will be an improvement  :y
But to be fair it runs as good unplugged as when I first had it can't fault the performance as I beat a golf off the line today  ::)
