Pages: [1] 2 3  All   Go Down
Author Topic: bottle jack  (Read 6391 times)
greenman
  • greenock
bottle jack
« on: 13 February 2012, 20:30:46 »
Thinking of buying a bottle jack.Would 2 tonne be enough for lifting one corner at a time on the omega?
Re: bottle jack
« Reply #1 on: 13 February 2012, 20:34:41 »
Your Omega weighs less than 2 tonne in total, so will easily lift one corner. Not sure where you'd locate it though.  :-\ Trolly jacks are easiest to use.  ;)
Re: bottle jack
« Reply #2 on: 13 February 2012, 20:37:07 »
Bottle jacks have a tendency to fall over, too.. I have one that I've used a grand total of once, ever. The trolley jack, on the other hand..
Re: bottle jack
« Reply #3 on: 13 February 2012, 20:41:38 »
Get a trolley jack instead. 2.5 ton minimum if you want it to last generally.
Bottle jacks are too unstable and and have too narrow a saddle, need to spread the load.
Re: bottle jack
« Reply #4 on: 13 February 2012, 21:02:01 »
Plus, you'll struggle to get a decent bottle jack under an Omega anyway ;)
Re: bottle jack
« Reply #5 on: 13 February 2012, 21:03:49 »
And that. In fact, some trolley jacks as well.
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: bottle jack
« Reply #6 on: 13 February 2012, 23:02:11 »
They're the Devils toys!!
Those are my principles, if you don't like them I have others.
Re: bottle jack
« Reply #7 on: 13 February 2012, 23:15:27 »
They can be very useful for some things,but supporting a car isnt one of them. ;)
My new 3 ton Clarke trolley jack doesnt quite go under the sill of an Omega.Have to lift the car on its springs an inch or so and then push it under with my foot.Most annoying. ::)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: bottle jack
« Reply #8 on: 13 February 2012, 23:21:10 »
« Last Edit: 13 February 2012, 23:23:54 by Seth »
Re: bottle jack
« Reply #9 on: 13 February 2012, 23:47:56 »
Mine isnt quite the same as that.Presumably a different model. :-\
Re: bottle jack
« Reply #10 on: 14 February 2012, 00:01:48 »
I use one of these with no problems:
From here: http://www.machinemart.co.uk/shop/product/details/ctj3000g-3-tonne-professional-garage-j
They aren't bad for the money. But Daz had one of those at Newent. rather thing. Talk about hair trigger when lowering the car. It wasn't possible to drop it slowly, sliiiiiight twist on the haaaaandlllllle WHAMO! Car crashes to the floor. Jesus Christ.  :o. I reckon it was made of recycled bits from Arkwrights til.  ;D
tidla
  • solihull
Re: bottle jack
« Reply #11 on: 14 February 2012, 00:17:13 »
owning the clark high lift model jack i can confidently confirm arkwright still works for the costing dept. cheap shite.
Re: bottle jack
« Reply #12 on: 14 February 2012, 00:20:15 »
I have seen others that worked fairly well. Not sure what Daz had been doing with his tbh. It was a bit poorly, and had been threatened with lobbing over the fence, except it was the only jack we had.
Re: bottle jack
« Reply #13 on: 14 February 2012, 00:27:38 »
I have one that looks like that, had it years, also have a 'High Lift' one, not really been used, neither fit under the Mig with a flat tyre, well they do, but not in the right place so have to lift the car and then put another Jack in a more appropriate place......guess that is quite a common problem though...... ::) ::) ::)
Re: bottle jack
« Reply #14 on: 14 February 2012, 00:30:32 »
I guess if the Jack is only ever used in the case of a puncture then, well...
... How many punctures do you have Mike? :)
Pages: [1] 2 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
