Author Topic: Front Door Lock  (Read 1170 times)
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Front Door Lock
« on: 14 February 2012, 23:38:45 »
When I lock the car - press the fob- all the doors lock except the front passenger door.
If I press the fob again to deadlock the doors then then the front door locks.
The door unlocks as normal.
Do you think it's the lock or maybe a wiring fault?
I just want to get all bits needed before stripping the door down......
best wishes
Simon.
Re: Front Door Lock
« Reply #1 on: 15 February 2012, 00:12:42 »
Its the locking "solenoid" mate - plenty of info on here  :y
Ninda
  • Slough
    • 2.6 CDX 03 + 3.2 Elite 03
Re: Front Door Lock
« Reply #2 on: 15 February 2012, 10:40:11 »
I had the same problem with the Driver side door, i changed that over and while i was changing it over the Passenger side door stopped working
WEIRED right?
Would you suggest its the Solenoid ?
Re: Front Door Lock
« Reply #4 on: 15 February 2012, 13:13:26 »
The motors can be repaired with just a £2 microswitch...
http://www.omegaowners.com/forum/index.php?topic=90642.0
Ninda
  • Slough
Re: Front Door Lock
« Reply #5 on: 15 February 2012, 14:05:50 »
Ok , thanks a lot guys :)
