My auto gearbox doesn't seem to change gear
Started by Keith Buckney, 20 February 2012, 07:42:12
Keith Buckney
Started out for work this morning and found my 2.2 CD Auto was a little 'sluggish'. Noticed that the gearbox doesn't change gear and it's really slow to move off once stopped.
Auto Addict
Any other signs, doesn't always start first time?
Any warning lights?
I like red cars
joff
Quote from: Auto Addict on 20 February 2012, 08:31:04
Any warning lights?
Are you thinking crank sensor  :-\
amba
First thing would be to check the autobox fluid level and if mieage is getting up a bit and you have no history of gearbox oil might also be worth thinking about getting it replaced along with the filter screen.
Tired oil will make a box quite sluggish with a tendancy to hang onto gears then bag as it chages up or down.Clean fresh oil makes a VERY big difference to its performance and not an expensive job to do.Excellent write up in maintenance section aswell.
As it's a 2.2 I'd check for fault codes. Although it does sound like it's in snow mode.
Auto Addict
Quote from: joff on 20 February 2012, 08:37:09
Any warning lights?
No, cam sensor.
I like red cars
Keith Buckney
Thanks for advice gents, will check oil - have been getting orange spanner light coming on intermittently, but clears as soon as I stop and restart. Have also been having snags when starting after short journeys.
Yup, i'd be looking at cam sensor. Crank sensor on the 2.2's is bullet proof.
Quote from: Keith Buckney on 20 February 2012, 07:42:12
Sounds to me like your car is setting f in 3rd gear ie in limp mode. Use 1 2 & 3 to prove  ;)
Auto Addict
Defo cam sensor, it needs replacing with a genuine one from a Vauxhall dealer, do not get one from anywhere else.
I like red cars
Quote from: Keith Buckney on 20 February 2012, 09:26:40
Fix the engine issue (soon) and you'll likely find gearbox cures itself.
Get a local member to read the codes, then take appropriate action as recommended here. Don't bother with garages, they universally do not understand cars.
Quote from: tunnie on 20 February 2012, 09:32:56
/Panto mode...
Oh no they're not
Quote from: Auto Addict on 20 February 2012, 17:34:25
Certainly possible, even likely, but we teach better diagnosis than that here, don't we ;)
Auto Addict
Quote from: TheBoy on 20 February 2012, 17:44:05
Totaly agree, but cam sensor doesn't always bring up the correct codes.
I like red cars
