It might be the fan switch or relay for the main fan, so only the auxiliary fan works. Engine, will go into the red and then cool down due to the auxiliary fan pushing air through the radiator
I'm sure somebody on here will know at what temperatures the fans switch on.
That could be a possibilty , i only heard the fans cut in yesterday when it had run into the red ....
I have topped the coolant up then screwed the filler cap on more secure than it was , the temp sits at 95 but no fans are cutting in ...i noticed the gauge rises a bit more when the car is turned off but then as soon as its driven it settles back to 95 .
Squeezed all the pipes with cap off and the stat appears to working correctly.
Where is the fan switch or relay thingy
easy to get to
What temp should the fans cut in normally , im thinking that all is fine but when it gets to a point of too much heat and needs the assitance of the cooling fans its just boiling over
