Author Topic: Air-con glove box  (Read 4688 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Air-con glove box
« Reply #15 on: 17 May 2012, 20:28:51 »
Hoses are not easy to get hold of new either I have one on order coming from VX Germany apparently
« Reply #16 on: 17 May 2012, 20:51:26 »
Asthmatic cc? Aye? Works well IMO.
The outlet behind the dash appears to be Independent of the cabin vents. Hot or cold, fast or slow, it's output appeared unchanged during the brief test as we installed it.
LFF64
  • HADDENHAM BUCKS
« Reply #17 on: 17 May 2012, 20:59:20 »
I am having mine regassed tomorrow as it is not as cold as it should be , just in case we get any summer  ;)
« Reply #18 on: 17 May 2012, 21:24:18 »
Law of sod says save your money Lff. Historically, any attempt by myself to plan for summer, be it garden furniture, holidays, buying summer clothes, or fitting ac glove boxes, instantly dooms the rest of the year straight back into winter.
 That's it now. Go buy a snow shuvel ;) ;D
    • E250 Est / Elroq
« Reply #19 on: 19 May 2012, 09:52:56 »
So then Chris....with a few days behind you, would you do this mod again knowing the performance (and probably why it was dropped)?
    • E250 Est / Elroq
« Reply #20 on: 19 May 2012, 09:54:15 »
actually, can you type up an afterthoughts paragrap?, covering comments since your 1st post....and ill move the original, and summary over to the guides section and get rid of the rest.
Cheers
« Reply #21 on: 23 May 2012, 00:50:11 »
Ok, after a bit of time with this installed.... day to day, short journeys with average outside temps, the benefits are minimal. But on a longer journey, ESP in hot weather where ac and fan speeds will be working harder, there is greater cooling involved. It's never going to reach fridge temperatures, but it will make an otherwise warm tepid drink cooler and more pleasant than it was.
 Reading between the lines this option was available on the pre face lift, but dropped as an option on the face lift, I suspect due to the ncdc 2015 telematics being installed in the glove box, some customers, i suppose, might drop the more profitable phone option in favour of the ac glove box. I guess GM took the choice away on economic grounds.
 Obviously owners with ncdc2015 telematics in the glove box won't find this usefull, unless the telematics is re sighted and looms extended with help from Vxlv6 (Thanks Andy and TB for thier help with that)  :y
But there we are, a cheap and easy install generally speaking, and you never know, it might help the re sale value... Maybe. :)
« Last Edit: 23 May 2012, 01:00:40 by chrisgixer »
« Reply #22 on: 23 May 2012, 01:18:46 »
Ok Jimbob,  I reckon that's good to go with replys 22 and 23 :)
Ta
« Last Edit: 23 May 2012, 01:23:23 by chrisgixer »
    • E250 Est / Elroq
« Reply #23 on: 23 May 2012, 07:05:22 »
cheers, ill do the biz later, thanks very much
