Just ordered fag wheel barings
Started by feeutfo, 15 May 2012, 12:06:11
...from All German Parts. Said to be oe supplier. Comes with the dust cap going by the pics.
Needed drop links any way so stuck a couple of barings on the order. Hopefully that's that annoyance sorted.  :)
Lots of nice pics on the web site now.
http://www.allgermanparts.co.uk/ourshop/cat_277900-Steering-and-suspension-components.html
Interested how you get on, as the Contitech ones are shite.
Aaeye conti tech on there now, it's banging away as well as the drop link ATM.
F.A.G. been on two weeks. All fine. No play.
Now fitted the other side.
As you an see, exactly the same as oe.  Baring numbers the same.  Afaict
How much?
Plus can we get the old hubs and see about fitting new bearings?
£66 each
http://www.allgermanparts.co.uk/ourshop/prod_2034000-Front-wheel-bearing-FAG-brand-OEM-713-6445-40.html
Got an old conti and old oe here.
What are we saying for procedure?
Belt the old ones out with a drift?
Freeze the new baring?
Heat the hub?
Hope the new one pushes in?
Where are we getting these "barings on thier own" from by the way? ;D
GmasterT
Yeah, never had an issue with FAG... thats not a double entendre!  ;D
Quote from: GmasterT on 22 May 2012, 20:21:54
I am waiting for TB to pipe up. ;D
Gaffers
So, i put it to oof...
The inner race does not exist separately. It is machined into the hub itself, and the races pop in to that, then the outer races in turn pop in to those.
There is no separate baring complete, that presses into the hub.
Tell me I'm wrong. :)
Quote from: chrisgixer on 22 May 2012, 20:49:57
You're wrong.
The inner race often gets "left behind" on the stub shaft on removing the old bearing .. but must be removed.
Given the "right" kit a complete bearing can be pressed into the ABS ring that is really just a bearing carrier. Most places though sell the ABS ring/hub + bearing as a complete unit.
the bearing itself is shown as one of the portions of 24 here..VX don't sell it as a seperate item
http://opeloem.com/opel/omega_b_1994_2003/front_axle_and_suspension/front_hub.html
Quote from: Entwood on 22 May 2012, 20:56:57
You're wrong.
vx don't sell it as it doesn't exist. If it does I can't find it.
I should add we are talking about the same thing. The inner race that gets left on the hub has been removed. Both of them. Then there the barings with plastic cage thing.
With all that romeved that leaves what I called the inner race, as I'm working my way into the baring, if you see what I mean. ( actually the outer race from the centre)
As you say, item 24 shows the hub with reluctor ring built in. Between that and the stub axle there is what appears to be a baring. A complete baring. Where do we get this complete baring...?
Theres no sign of it on the web. There for I dont believe the complete baring exists. There for there is nothing to press in.
