Author Topic: Hbv internals. (and some revenge....)  (Read 2923 times)
« on: 03 August 2012, 22:47:24 »
(...,by cutting the bastward thing in half. MWAAAHAHAHAAA.)
Some innards if anybody is interested.
And this is where mine leaked. Hole pointed out by the screw driver.
So I guess the internal lower brown seal failed. :-\
Re: Hbv internals. (and some revenge....)
« Reply #1 on: 03 August 2012, 22:50:40 »
Interesting.. Valve looks very restrictive. :-\
« Reply #2 on: 03 August 2012, 22:59:09 »
Now you mention it, yes it does. The bore closes in as well. :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 04 August 2012, 06:52:14 »
Is that a genuine VX one Chris or a pattern ?
« Reply #4 on: 04 August 2012, 07:21:44 »
Presume vx. As it was on the car when it came to me. One previous owner.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #5 on: 04 August 2012, 09:14:46 »
No wonder it failed look at that swarf everywhere! ;D ;D
« Reply #6 on: 04 August 2012, 10:37:35 »
Although yours leaked where you said, I think the fault if the red seal on the metal shaft, which is supposed to keep water out of vacuum area ('the spaceship')
« Reply #7 on: 04 August 2012, 10:39:03 »
Well done C - a very worthwhile exercise. :y
« Reply #8 on: 04 August 2012, 14:00:39 »
The hole pointed too with the screw driver is moulded/designed in. So yes your right. If the hole wasn't there the vaume area would fail open and stop operating as the water pressure would hold the valve open.
And if I've worked it out correctly that would give no heat...?
« Reply #9 on: 04 August 2012, 14:14:51 »
Having just removed the brass shaft from the remains, that seal is a very loose fit around the brass. With the action of the valve opening and closing the seal looks to take all the wear.
The fact that I've suspected a very slight leack for a couple of months and summer inducing alot if ac action in the cabin, all seems to support a gentle leak worsening over time. That lower seal fits the bill nicely.
What arrangement do modern cars have, I wonder?
« Reply #10 on: 04 August 2012, 14:25:42 »
No idea. but my Cortina & MkI Cavalier just used a heater box & either used the warm air the heater matrix produced or by-passed it, far better than a heater valve that 'old' cars used to have. A HBV seems to be the price we pay for modern auto climate control ............. I wonder what my Merc has  ::) ::) ::)
« Reply #11 on: 04 August 2012, 16:41:46 »
That gixer angle grinds everything he sees...
...I think his Gary Grinder is his version of Sammy Sledge.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #12 on: 04 August 2012, 16:47:15 »
hope you made sure it was the broken one you sliced in half chris  :D ;D
RIP Paul Lovejoy
Andy H
  • Auckland
    • Mazda MPV
« Reply #13 on: 04 August 2012, 19:26:08 »
I have always wondered what it looked like internally. :-\
Worthwhile posting this pic in 'testing' so Jimbob can add it to the useful pictures. :y
Abiton
« Reply #14 on: 04 August 2012, 21:12:22 »
Nice work Chris.  :y
Unless I'm missing something, it looks like that has to be assembled as two plastic halves heat-welded (or whatever it's called) together around the valve.  So 'unwelding'/cracking anywhere on that vertical seam would be another failure mechanism.  Whole thing looks 'fragile' more than anything, but that perception is probably biased heavily by knowing their reliability record.
Page created in 0.018 seconds with 15 queries.
