Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 ... 27   Go Down
Author Topic: Oh no, what have I done .... ?  (Read 54812 times)
Re: Oh no, what have I done .... ?
« Reply #60 on: 09 October 2012, 16:56:43 »
Couldn't find anything untoward in or around the cambelt, so have put everything back together with the plan to do the pedal trick when I get home.
That'll be interesting  :-X
Once put back together, try running engine without aux belt on. That way water pump won't be running, rule that out. Don't run it for very long though  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #61 on: 09 October 2012, 17:09:51 »
Ok pal. Will do  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #62 on: 10 October 2012, 10:27:54 »
Before getting the spanners out again, though I'd try the pedal trick. Bearing in mind I haven't done this before on the car, I don't know if there were any codes already stored. Having said that, I was pleasantly surprised that there were only 5 codes -
0120 - Throttle/pedalPosition sensor/switch "A" circuit range/performanceProblem
0220 - Throttle/pedalPosition sensor/switch "B" circuit range/performanceProblem
1110 - Intake Manifold Valve 1 Open
1111 - Intake Manifold Valve 2 Open
1700 - Service Vehicle Soon Request from Transmission Control Module
Ignoring the last code, it would seem I have done something very silly at some point during reassembly. At least I'm hoping that's the case  ::)
I guess I'll have to go through what I've already done, but any pointers would be appreciated  :y
Thanks for all the help and advice so far, and my ignorance shows when I thought that stupid washer was involved  :-[
« Last Edit: 10 October 2012, 10:35:41 by jonny2112 »
« Reply #63 on: 10 October 2012, 11:04:37 »
Have you plugged in the little solenoid valves that operate the multirams? (one on the bagpipes in front of the engine, the other on the rear passenger corner of the plenum)
Ditto the throttle body. Has the electrical connector to this been refitted?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #64 on: 10 October 2012, 12:20:12 »
I thought everything had been refitted, especially as I've had the plenum on and off a couple of times this past while :-\
I'll check all the connections again though, thanks Kevin  :y
« Reply #65 on: 10 October 2012, 13:30:43 »
They may be stored codes, of course. Did you turn on the ignition while they were disconnected during the job?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #66 on: 10 October 2012, 14:42:37 »
No I don't think so, but they could be stored codes indeed. Can they be reset by me so that I can try again? Or is that a job for tech2?
It does quite fit in though with the work I was doing? I've a day off tomorrow so hope I can get to the bottom of it!
Wish I'd had the wit to check for codes initially, before wasting time stripping it down again  :-[
« Reply #67 on: 10 October 2012, 16:02:24 »
Well, I wouldn't worry too much about the codes at this stage. There's nothing there to indicate what the rattle might be.  :-\
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #68 on: 10 October 2012, 16:36:32 »
I know. I think I'm getting carried away, thinking its something simple.
We'll see tomorrow  ::)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #69 on: 11 October 2012, 15:09:50 »
Bloomin' weather!! Was outside for five minutes and got absolutely soaked  >:(
Didn't see anything untoward or disconnected though.
Going to take the plenum off again, and the inlet and the sandwich plate so I can check the intakes, and make sure everything is put back in place.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #70 on: 11 October 2012, 17:58:45 »
Just been looking through the guides again, and it states there is a vacuum hose on the inlet. I don't recall seeing this on the initial removal, and therefore did not replace it. All I remember is the wiring block.
Where does the hose connect to, or where from, so I can check?
Cheers  :y
amba
  • Medway towns
    • German V6
« Reply #71 on: 11 October 2012, 18:05:21 »
Thin vacuum pipe runs from the vacuum box down by the front "bagpipes" along the n/s cam cover then connects to a little curved rubber pipe onto the rear multirams almost directly next to the black cable plug
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #72 on: 11 October 2012, 18:09:38 »
Just thinking actually, is there a small vacuum pipe attached to the inlet which attaches to the underside of the throttle bodies? It's not actually removed from the inlet as its already been disconnected from the throttle?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #73 on: 11 October 2012, 18:11:36 »
Cheers mate, that's at the back of the plenum?
amba
  • Medway towns
    • German V6
« Reply #74 on: 11 October 2012, 19:14:27 »
Yes...connects at the back n/side of plenum just by the bracket that holds the cable tray.There is a curved peice of rubber that fits to the multiram and the vacuum pipe just pushes into the end
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 ... 27   Go Up
Page created in 0.014 seconds with 14 queries.
