Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 ... 27   Go Down
Author Topic: Oh no, what have I done .... ?  (Read 54813 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Oh no, what have I done .... ?
« Reply #90 on: 12 October 2012, 12:51:42 »
That's what I'm starting to think too Albs, that something is inside.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #91 on: 12 October 2012, 13:08:32 »
Despite creating a new YouTube account, I can't seem to upload as it doesn't recognise my sign in (despite being already signed on on the app!).
Could I email it to someone to upload on my behalf please?
« Reply #92 on: 12 October 2012, 13:30:17 »
If you suspect a foreign object has got in, remove each spark plug and check for signs of damage.
amba
  • Medway towns
    • German V6
« Reply #93 on: 12 October 2012, 13:31:52 »
If you still have the same original noise and you have hand rotated all the ancillaries with aux belt removed and non of them are the issue,it is now pointing more towards something being left under a cam cover prior to fitting it back on.
That would certainly account for the noise which hopefully hasnt got any further inside the engine.Might be worth just allowing it to run with a long screw driver to your ear and on each cam cover in turn and see if the noise from 1 side to the other is much different.That would atleast confirm if something is loose under it and also allow you possibly only need to remove 1 cover.
A stethoscope probe would be ideal otherwise,but long screw driver would suffice
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #94 on: 12 October 2012, 13:56:15 »
Took off the offside cover but can't see anything untoward.
amba
  • Medway towns
    • German V6
« Reply #95 on: 12 October 2012, 14:01:13 »
Looks like you may need to remove the otherside too just to be totally certain nothing is in there
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #96 on: 12 October 2012, 14:07:30 »
Plugs seem ok too so have to try the other side too.
« Reply #97 on: 12 October 2012, 14:09:44 »
Just an idea, but when you disconnected the fuel lines, you wrapped them in paper towels or similar? Checked those are free and clear?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #98 on: 12 October 2012, 14:17:23 »
Actually there is a little bit of watery mayo on the inside of the cover. Don't recall it being like that the first time, but it could have been. Would that mean anything?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #99 on: 12 October 2012, 14:17:57 »
Thanks tunnie, yes they're clear.
« Reply #100 on: 12 October 2012, 14:18:20 »
Just some moisture/water mixing with oil, nothing really to worry about  :y
« Reply #101 on: 12 October 2012, 14:18:48 »
Bugger, another one to cross of the list  :(
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #102 on: 12 October 2012, 14:19:22 »
Cheers. Onto the other side then ....
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #103 on: 12 October 2012, 16:06:23 »
Other side looks clear too.
Ah well, back to the drawing board. Stupid torque wrench sheared one of the cam cover bolts  >:(
Have to try and borrow another wrench, though cant get a replacement bolt until Monday.
Why did I bother with this job  :(
amba
  • Medway towns
    • German V6
« Reply #104 on: 12 October 2012, 16:46:28 »
Its turning into a real PITA for you,sorry to hear that.
How did a cam cover bolt shear at only 8nm  :o
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 ... 27   Go Up
