Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 27   Go Down
Author Topic: Oh no, what have I done .... ?  (Read 55028 times)
0 Members and 3 Guests are viewing this topic.
Re: Oh no, what have I done .... ?
« Reply #105 on: 12 October 2012, 17:00:12 »
8Nm is barley nipped, its so low its very hard to judge by hand. Was the torque wrench faulty?  :-\
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #106 on: 12 October 2012, 17:29:18 »
I think it must be faulty. Knew I shouldn't trust it.
Miss2112 has uploaded the noise .....
http://www.youtube.com/watch?v=lmzZ3V5-VYg
Hope the link works, as it'll give you an idea.
amba
  • Medway towns
    • German V6
« Reply #107 on: 12 October 2012, 17:49:19 »
That doesn,t sound like anything metalic has dropped inside the negine to me. ???
Have you checked the small rubber hose join on the SAI tube that runs just by the o/s coolant transfer pipe for a split...that noise sounds more like manifold or exhaust related from the clip
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #108 on: 12 October 2012, 17:59:08 »
Thanks amba. That would tie in to the fault code too.
I haven't found anything disconnected, but I'll start checking for damage / splits too  :y
amba
  • Medway towns
    • German V6
« Reply #109 on: 12 October 2012, 18:09:06 »
That noise does sound more like an exhaust blow or similar....I really doudt that is anything inside engine or cam covers.
That short peice of black hose joining the 2 peices of the SAI pipework would make a similar noise if it had a split...seem to remember somebody replaced manifold gasket only to find it was the pipe that had a split in it.Should be able to feel a definite blow if you carefully feel around it whilst engine is running...be carefull though as pipes are hot  :o
« Reply #110 on: 12 October 2012, 18:50:45 »
I wouldnt like to say tbh.Sounds just like my diesel cavalier.Hopefully one of the experts will recognise the problem from the soundtrack. :y
« Reply #111 on: 12 October 2012, 18:53:31 »
2.6, no SAI ;)
« Reply #112 on: 12 October 2012, 18:57:47 »
Is it definitely running on both banks ? Its almost as if its only running on one. :-\
« Reply #113 on: 12 October 2012, 18:59:49 »
Sounds metallic , is the oil low  :-\
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #114 on: 12 October 2012, 19:26:00 »
isnt that a tappety noise not sure of the construction but are there lifters or hydraulic tappets which are not getting lubricated
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #115 on: 12 October 2012, 19:32:18 »
There was an oil leak, but the oil has been topped up. Left it running for a while but no change. Maybe needs run for longer? But it does sound tappety!
Sounds like its coming from the plenum but there's nothing in there really. I didn't physically check it though. Mmmm.
Be a nightmare trying to find a split pipe if that's what it is  :-\
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #116 on: 12 October 2012, 19:33:55 »
How could I test this? I had thought fault code may have thrown some light on that?
Worth disconnecting one of the coil packs at a time?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #117 on: 12 October 2012, 19:44:44 »
Looking at engine construction under the cams are followers and a" hydraulic valve adjustment mechanism" are the followers getting the oil they require. Something blocked by disturbed muck.
« Reply #118 on: 12 October 2012, 19:47:11 »
That would work.If disconnecting one doesnt make any difference then youve narrowed things down.Im only thinking out loud though.Im not an expert by any stretch. ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #119 on: 12 October 2012, 20:32:55 »
I'll maybe give that a go. Can't do any harm.
Bit late now though and working over the weekend  :'(
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 27   Go Up
