Author Topic: sky crap again  (Read 8057 times)
bored bigyin54
  • south wales
    • black beast
sky crap again
« on: 22 November 2012, 16:04:54 »
i know i said it before , but we got heavy rain again no signal again . >:( >:( >:(
Kate
  • Cornwall
    • Drives people mad
Re: sky crap again
« Reply #1 on: 22 November 2012, 16:42:39 »
is it possible to buy a better dish? I've seen some massive ones in London! Dishes I mean! ;D
bored bigyin54
  • south wales
    • black beast
Re: sky crap again
« Reply #2 on: 22 November 2012, 16:45:57 »
just been in contact with sky . they said have to pay 69 pound call out fee .so i may stop sky alltogether >:( >:(
Re: sky crap again
« Reply #3 on: 22 November 2012, 16:48:58 »
Sooner the better yin, sooner it's sorted sooner you are happy. ::)
Re: sky crap again
« Reply #4 on: 22 November 2012, 16:54:58 »
Phone and say you will cancel if they wont fix it , usually works a treat  :)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: sky crap again
« Reply #5 on: 22 November 2012, 17:06:06 »
your mate tunnie offered to have a word a while back  ::) ::) ::)
OOMV6
Re: sky crap again
« Reply #6 on: 22 November 2012, 17:07:40 »
May not be sky fault but something to do with The dish and LNB.
Steve B
  • Leicestershire
Re: sky crap again
« Reply #7 on: 22 November 2012, 17:10:06 »
you thinking pattern part ;D ;D ;D ;D
Re: sky crap again
« Reply #8 on: 22 November 2012, 17:35:44 »
Have noticed on my setup that the signals are different on each tuner, the best one is only about 75%.  But have read somewhere that if not alined properly this is what causes the signal loss in bad weather, apparenly a dish should still be ok with an inch of snow covering it.
Maybe a local guy from your free press could re align it or check it for you for a few quid.
D
  • SE London
    • 03 3.2 Elite
Re: sky crap again
« Reply #9 on: 22 November 2012, 17:52:15 »
Really? Seems an odd response if your service isn't working. Why dont you change providers?
Although did Tunnie not offer to sort it out for you previously?
Re: sky crap again
« Reply #11 on: 22 November 2012, 18:04:58 »
I highly recommend BT's Vision.  Of course you need their phone line and Broadband Hub, but I have no complaints about any of it.
Used to be a Sky customer when it was £10 a month for a complete package, but now I think it is over priced for what I actually would use! ;)
Boggy
Re: sky crap again
« Reply #12 on: 22 November 2012, 18:17:38 »
If your signals low and it's unlikely the dish has moved, check your cable first, the ends should unscrew off the cable. If the copper is black/dark green then it's water ingress, either trim cable back till its copper, if you don't have enough spare length, change the entire length. If that don't cure it, then it could be that the dish has dropped slightly over time, it doesn't have to move far to lose signal or strength, sounds like to be water to be honest.
Re: sky crap again
« Reply #13 on: 22 November 2012, 18:18:42 »
OOMV6
Re: sky crap again
« Reply #14 on: 22 November 2012, 18:38:44 »
Need to get it checked - signal strength too.
My set up was fine. I changed receiver and then only received 10% of channels. Changed dish to a slightly larger one I had lying around - all fine.
If rains causes a problem it is unlikely to be the fault of Sky
