central locking problem
Started by watto, 28 November 2012, 08:23:49
watto
omega 2.6 petrol.
drivers door will not lock using fob.
locks ok with key.
Quote from: watto on 28 November 2012, 08:23:49
omega 2.6 petrol.
locks ok with key.
Sticky activating rods, or failed lock "solinod".  Easily replaced. :y
Here is the OOF Guide on how to replace:
http://www.omegaowners.com/forum/index.php?topic=90504.0
zirk
Assuming the Fob is working or should work, also worth checking your Ignition Barrel is fully popping out when removing the Key before you start ripping things apart as this can cause the same symptoms.
plym ian
battery in fob?
or fob out of sync with car?
Quote from: plym ian on 28 November 2012, 16:05:57
battery in fob?
That would affect all locks Ian, but the OP is stating the drivers lock (only) ;)
