Author Topic: Front passenger door un-lockable - and MOT due in 5 days? Help  (Read 2134 times)
markomega25
  • Morden, Surrey, A3 gateway
The front passenger door lock has been a bit lazy of late so have had to lock it by pushing the button/knob down manually, yesterday it unlocked ok (fine) but now it's locked solid with door shut.
Cannot pull the knob up even with pliers and manipulating the inner and outer door handles at the same time makes no difference. I think it's the deadlock jammed in place.
Is there a way to free this off without having to destroy the inside door card to get at it?
My MoT is due in five days - is an unlocking front passenger door an MoT failure?
Thanks in advance.
M
kevinp58
  • kent
    • 2002 3.2 elite
Re: Front passenger door un-lockable - and MOT due in 5 days? Help
« Reply #1 on: 16 December 2012, 23:28:19 »
Yes it would fail on the door not opening but not sure how to help out I am sure somebody here will be able to help though
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 17 December 2012, 00:56:03 »
which year is yours?  If PFL I can get the door card off without too much damage, it certainly wont be noticable once but back on anyways :y
markomega25
« Reply #3 on: 17 December 2012, 13:26:17 »
It's a year 2000 facelift Elite saloon, and I can't see a way of getting at the screws that hold the panel on with the door shut.
Going to try it again later but not holding out much hope as the Electrics on the lock appear to have completely died. As it's an MoT fail it looks like I will have no choice but to butcher the panel. Anyone know the least damaging way of pulling it off?.
markomega25
« Reply #4 on: 17 December 2012, 14:10:28 »
Update. Managed to get it unlocked, phew! Perhaps charging the battery overnight gave the electrics a bit more oomph, and the warmer weather today helped free it off.
Left that door unlocked (parked up against garage) as reluctant to lock it again until I have managed to get the card off and have a look.
How likely is it that just lubricating the bits will help? It's unlikely I will be able to replace the mechanism before the MoT in the next few days so will not lock it again until MoT has been done.
« Reply #5 on: 17 December 2012, 14:18:07 »
It's almost always the microswitch in the central locking motor so I doubt lubrication would help. As it's failed in the deadlocked state once, I wouldn't trust it again, TBH.
Not too bad a job. Have a look here:
http://www.omegaowners.com/forum/index.php?topic=90504.0
http://www.omegaowners.com/forum/index.php?topic=90642.0
markomega25
« Reply #6 on: 17 December 2012, 17:15:47 »
Thanks Kevin that's really help full.
MoT booked for tomorrow, so hopefully if nothing major leads to a fail I will then try replacing the micro-switch s suggested.
Looking at the RS website, they sell the switch currently for £1.42p so I might order several in case the drivers door one starts to go.
On the RS website the review confirms the switch is the VX standard part, but a weak link.
http://uk.rs-online.com/web/p/microswitches/2900463/?searchTerm=290-0463&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D504E266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B337D5B5C732D2F255C2E2C5D5C647B332C347D2426706F3D313426736E3D592673743D52535F53544F434B5F4E554D424552267573743D3239302D303436332677633D4E4F4E4526
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #7 on: 17 December 2012, 20:06:57 »
Lets hope they don't move it and lock it before they MOT it ;)
markomega25
« Reply #8 on: 19 December 2012, 02:00:37 »
Well, good news it passed the MoT fine and the door was not a problem and is unlockable so long as I don't double/deadloock it.
So now I will order the micro switch and set about the repair, but thankfully there's no absolute rush but will do it pronto.
Will let you know how I get on with it (following Kevins great how to guide).  :y
« Reply #9 on: 19 December 2012, 19:19:15 »
That IS good news matey! now you can change/repair the lock solenoid at your leisure without any pressure!  :y
