WTD: 2001 3.0 Manual ABS ECU
Started by RN55ONE, 10 January 2013, 16:40:25
RN55ONE
Wanted - ABS ECU to fit a 3.0 manual elite - 2001 (facelift).
Got one from a 3.0 auto facelift elite,year 2000 .I dont think transmission type makes any difference,but it would be best to check. :y
Do you want the pump with ECU attached or just the ECU by itself ?
Quote from: Albitz on 10 January 2013, 16:47:26
Needs to be like for like or will need a reconfig
Didnt know like for like was to that extent.Thanks Rob. :y
Its coded to immobiliser ecu as well.
Whats wrong with the current one. they are robust
Quote from: TheBoy on 10 January 2013, 19:20:36
You sure ? I wish I had a fiver for every post Ive read about loss of ABS/TC/speedo etc. :-\
serek
Quote from: Albitz on 10 January 2013, 20:18:45
that about right , replace few of those and never had any problem
cant see any different if is program to manual or auto :y
coding has engine size and gearbox type,  you also get very weird goings on if you have a new blank ecu as I did when I bought my last car.
I think TB has read engine ECU not ABS Ecu :y
RN55ONE
My speedo has started to go down to zero and the TC light comes on.
I only replaced it just over a year ago.
If anyone does have one, please msg me.
Well,I have one but Im currently confused as to whether it would be suitwble for you. :-\
Ignore me, I'm talking shit. Can't read, sorry  :-[
So - will an ABS ECU from a year 2000,facelift,3.0 auto be suitable. ?  :-\
Just my 2p's worth .. a second hand unit may well be about to fail in exactly the same manner as your old one ... there is no way of knowing .. for that reason I had mine (on the old 2.5 ) repaired ... no need to worry about configuration as it is "your" ECU .. and it came with a 2 year warranty .... £130 then don't know how much now...
Worth a thought ?
Quote from: Albitz on 11 January 2013, 20:43:37
No, wrong gearbox
serek
Quote from: TheBoy on 11 January 2013, 20:52:13
No, wrong gearbox
can you explain why this ecu wont work please  :)
what symptoms will be seen
