Can be done....
Started by RobseyMV6, 17 January 2013, 21:28:29
Quote from: chrisgixer on 24 January 2013, 12:38:45
There are also aftermarket modules available for efi and abc/tc if you want to be Gay about it cem. ;)
...although abs and tc shouldn't be too hard for someone who knows whet they're doing. :-\
Efi, v8 ecu usually goes with the engine. But shouldn't be too hard with a mega squirt if it came to it, going by past conversations over a curry. :)
Pretty easy to sort with the two wiring diagrams and both cars/looms in front of you I would have thought :-\
Basically you remove the plug from the Omega body to the engine ECU, and transfer the pins to the correct locations on the plug from the donor loom. This should then plug straight onto the V8 ecu and hopefully all work as expected :y
Not that anything is ever that simple :-\ is it ::)
Quote from: cem on 24 January 2013, 12:28:40
ok..assume that you solved all mechanical problems of ftting a v8 and a suitable gearbox(model still a question in my mind) how will you solve odo,dials,mid etc etc..  :-\
The mechanical problems are worthy of more consideration than that though.
With a steering box removed, for example, I am assuming the engine will fit and the gear box lever will line up, although I've seen talk that it sits a bit too far forward. Possibly fowling 1st 3rd and 5th. Won't find out what dictates that until we offer it up.
I am assuming also, that a Nissan Almeria(?) steering rack can be made to fit, as that's what rats used.
But then there's the question of the rearward bush on omega wishbones. It's unreliable. Degrades quickly , and I suspect doesn't give a particularly accurat feel to the steering even when new.
So before sticking the lump in, it might be wise to discuss subframe options for a different design rear bush if one exists?
Are Carlton or senator options worth a look? I presume Holden floor pan options are too wide and too different a design?
IF a Commodore/Monaro subframe could be persuaded to fit, then that should see most of the steering and suspension issues resolved, as you could use the entire front suspension, all of which can be upgraded quite easily :y (Pedders and others do bushing kits that replace all the rubber joints from the front end).
What this arrangement would do to the geometry is anyones guess though :-\
The other problem, is that the steering column exits the bulkhead at a very specific point. Is this compatible with a steering rack? And by doing away with the steering box, would the column foul the exhaust anyway.
I suppose it would be possible to replace the chassis rails, bulkhead and front end of the transmission tunnel with
Holden ones, allowing the entire Holden front end to be used from the steering column forward.
A substantially rear ended Monaro might be the onestopshop for this :-\
The simplest solution is to use as much of the Omega as possible... I need to get those arms fitted and put some miles on them...
Senny/Carlton subframes are configured for inline engines, so might not be much use.
Having said that, would an earlier subframe from any of the following chassis be suitable:
VL, VN or VP.
And how different, if at all are they from the Senator B subframe? :-\
Do keep up at the back ;D that's the car being built in the first post ::)
Corvette , now were talking  :P :P
serek
Quote from: chrisgixer on 24 January 2013, 14:46:03
bloke who done converion in poland use monaro rear subframe
Could it be that simple?
Marry a Monaro engine and subframes with running gear, to an Omega body?
By that I mean, take a monaro preferably crash damaged, effectively just lift the body off leaving the wheels, subframes, engine, gear box and drive train on the floor, and place an omega body on top?
Quote from: serek on 26 January 2013, 22:50:27
That's great info Serek. Thankyou.
Any more photos or links? I was actually talking about the front subframe, being honest, to try and change that front wishbone rear bush on the omega for something more reliable.
Do you think the monaro front subframe would fit too? :)
Bolt off, bolt on :y
Will post a couple of links int morning :y
Think this is what you're looking for...
http://www.ebay.com.au/itm/HOLDEN-VB-VC-VH-VK-COMMODORE-6CYL-8CYL-K-FRAME-CROSSMEMBER-NOS-GENUINE-/170971973076?pt=AU_Car_Parts_Accessories&hash=item27ceb945d4&_uhb=1#shId
Only issue is whether or not the column lines up with the input shaft on the rack :-\
Ps, I have asked about postage ::)
This is the later one, so 2004-2006/7...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200564177240&fromMakeTrack=true
Previous post is for an earlier version, mid eighties :-\ Senator/Carlton era :-\
