Can be done....
Started by RobseyMV6, 17 January 2013, 21:28:29
Quote from: ex taxi al on 23 January 2013, 11:56:53
The GM LS series is probably the most reliable engine ever made :y
And as for the weight issue, a large displacement V8 produces a level of torque from idle that a four pot turbo shastbox can only dream of ;D . And as we all know, without torque, horsepower means nothing :y
Take the Monaro as an example, can be reliably supercharged to well over 500bhp, will reach the thick end of 170, even in standard tune, yet does barely 1500 rpm at 70mph (120kph). At that speed, your clit is probably doing nearer 4000rpm, and using almost as much fuel.
And knowing Renault parts prices, the V8 is cheaper to service too :y
my clit even 7K rpm consumes a0.00000.. fraction of a v8 ;D   seriously at 120 must be around 3K (5th) will check tomorrow..
renault is produced here (factory in Bursa) so parts relatively cheap compared to omega.. even I can change engine at every oil change ;D  (exaggerating of course)
now as for service, your v8 takes twice oil, twice sparks , everything twice :-\
days of big monsters are long gone.. may be not in America but here :(
Quote from: Broomies Mate on 23 January 2013, 18:57:29
LS1 = 188 kg Wet
M62B44 = 221 kg Dry (+ 9.15l of Oil)
C20XE = 145 kg Wet
Cant find the weight of a C20LET online, but I'd imagine marginally more than the C20XE for obvious reasons.
C20let around 130 kg.. and considering the axels, carrier weight and width for chasis will bring more weight to car :-\
Broomies Mate
Quote from: cem on 23 January 2013, 19:27:18
LS1 = 188 kg Wet
C20XE = 145 kg Wet
How can it be lighter than the XE?
Quote from: Broomies Mate on 23 January 2013, 19:28:50
LS1 = 188 kg Wet
C20XE = 145 kg Wet
probably similiar all I can find was this.. may be light flywheel..
RobseyMV6
Ls will do more MPG then omega 3.0 and 3.2 v6 i get 36 out my one at 80 on motorways
Around a see 28.5 but never sort sort runs...
Quote from: cem on 23 January 2013, 19:30:00
LS1 = 188 kg Wet
C20XE = 145 kg Wet
aluminium block v8 is not dissimilar weight to y32se or x30xe due to having an iron block. ;)
Quote from: chrisgixer on 23 January 2013, 19:49:40
LS1 = 188 kg Wet
C20XE = 145 kg Wet
V6 lumps out of question anyway..  they are not race bred engines.. :-\
Quote from: cem on 23 January 2013, 19:58:04
LS1 = 188 kg Wet
C20XE = 145 kg Wet
define a race bred engine?
Me,If I were thinking of a similar project I would be buying an old lexus LS400 (plenty around the £500 mark) and having a look at dropping its engine into an Omega.A really well engineered Japanese quadcam v8,rather than an old over engineered U.S. boat anchor. :)
Broomies Mate
Quote from: Albitz on 23 January 2013, 20:09:36
As already said in the thread, Quad Cam engines are way too bulky, and from a performance POV, not much touches the LSx engine for size:power ratio.
Quote from: chrisgixer on 23 January 2013, 20:01:54
LS1 = 188 kg Wet
C20XE = 145 kg Wet
engines originally designed for race.. they are later put to production for daily use with lower power rating..
Quote from: Broomies Mate on 23 January 2013, 20:15:06
Can be done.....
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/118587-rats-1005hp-omega-v8.html
LS7 with supercharger then ::)
...being run on Moonshine or jetfuel :y
Obviously the Renault 1.4 fourpot was developed especially for circuit racing, only being fitted to 7 billion(ish) cars for homogolation purposes :P
It is indeed, and has been done in the rats omega. But the heads are wider, being dohc. They definitely fitted a rack with that engine.
LS or LS? ;D.
Lexus is 4litre though? Although just as easily tunable. But then the Chevy v8 well, that's the one to have. But costs more.
Decisions decisions. :y
I suppose it depends which is most suitable to omega running gear. Cooling, Exhaust, Auxiliarys, ecu and security stuff....etc?
Not much matches a Chevy v8 though, its very hard to beat pound for pound on bhp. You might have to remove the box on a Chevy v8. Where as it definitely will have to come out with a dohc lump.
Quote from: cem on 23 January 2013, 20:15:52
LS1 = 188 kg Wet
C20XE = 145 kg Wet
Such as...? :)
