Can be done....
Started by RobseyMV6, 17 January 2013, 21:28:29
Ps, if my rough measuring is correct, the steering box will come right to the end of where the ht lead disappears into that black plastic bit on the ht lead cap.
Broomies Mate
What is the expected output of that engine?  Which LS engine is it?
One of these days one of us is going to have to get one on a hoist, drop it in and see what's what. All the calculation in the world won't tell you what offering one up will. ;)
Quote from: chrisgixer on 21 January 2013, 23:22:27
Dohc heads are way too big.
This is an LS v8 pic taken from the gear box end obviously.
Push rod actuated cams may be a little agricultural, but they do make for a very compact cylinder head.(runs off a single cam in the v)
Heads being fine for width in the omega engine bay. Main issue is the manifolds exiting, and the widest part being the spark plug leads/caps.
Afaict its an extremely compact, light, powerful, and reliable engine. Comparatively speaking.
No leaking sumps or cam cover gaskets. Coil pacs last longer. Longer service intervals. Only issue is getting it all in. And self control on the loud pedal once it is ;D
It looked like they may have trouble shutting the bonnet on the first video. A minor issue. :)
The one pictured is an ls3 iirc(?)
Power goes up with the ls* number
Early ls1 as in the one gm planned for the omega was about 320 iirc?
Ls2 a fair bit more
Ls3 over 400bhp.
I'm sure 2woody will have more accurate figures, but its not really a problem to get 400 out of 1-3 with basic tuning naturally aspirated. Super charging 500hp ish.
Robsys monaro puts put 500 iirc, with a sooohoooHOOOOper charger and monkish mapping. Which runs better with a more manly fuel pump. :)
Quote from: Kevin Wood on 21 January 2013, 23:37:34
yep. It'll fit. Question is how much agro, and getting auxiliarys working. It's a bit tight at the front too, notice they moved the battery.
Quote from: chrisgixer on 21 January 2013, 23:46:19
Things like the battery are easily moved, though - into the boot if necessary.
Broomies Mate
Wait up fella's.
We know the e39 'bay is similar in size, yet they fit a v10 in it without any inherent problems.
It's clear the Omega V8 wasn't produced because of financial issues rather than the commonly used 'cooling' excuse.
Broomies Mate
Lets not forget the 6.2 fitted to a C Klass.  :-\
Quote from: Broomies Mate on 22 January 2013, 00:00:26
Wait up fella's.
Don't think the e39 has a steering box? IMO, reading between the lines, its was the closeness of the steering box, and the resulting narrowness of the headers on that cylinder that caused the problem.
IMO of course. ;)
Certainly the "internal cooling ways" description gm released doesn't stack up with the motor. It's as bullet proof as they ever get.
Quote from: Broomies Mate on 22 January 2013, 00:04:11
Oh yes let's. ;D
Do they have a manual box?
Broomies Mate
Quote from: chrisgixer on 22 January 2013, 00:06:06
Wait up fella's.
IMO of course. ;)
Steering box on the V8's  :y
Quote from: Kevin Wood on 21 January 2013, 23:51:01
They moved the abs too. And obviously no ac yet. ::)
Broomies Mate
Quote from: chrisgixer on 22 January 2013, 00:07:50
Oh yes let's. ;D
No - 7speed Auto IIRC until the latest variant.
Quote from: Broomies Mate on 22 January 2013, 00:11:04
Oh yes let's. ;D
Tremac t5 box then, means a gm lump. Unless making one off bell housings. :o
If someone brings an engine-less Omega round we can always try dropping the 390 in for giggles..  ;D
