Can be done....
Started by RobseyMV6, 17 January 2013, 21:28:29
Quote from: Broomies Mate on 23 January 2013, 20:15:06
Quote from: Albitz on 23 January 2013, 20:09:36
Me,If I were thinking of a similar project I would be buying an old lexus LS400 (plenty around the £500 mark) and having a look at dropping its engine into an Omega.A really well engineered Japanese quadcam v8,rather than an old over engineered U.S. boat anchor. :)
As already said in the thread, Quad Cam engines are way too bulky, and from a performance POV, not much touches the LSx engine for size:power ratio.
if I would choose an engine for race it would be a japanese not gm built..
Quote from: chrisgixer on 23 January 2013, 20:24:42
Quote from: cem on 23 January 2013, 20:15:52
Quote from: chrisgixer on 23 January 2013, 20:01:54
Quote from: cem on 23 January 2013, 19:58:04
Quote from: chrisgixer on 23 January 2013, 19:49:40
Quote from: cem on 23 January 2013, 19:30:00
Quote from: Broomies Mate on 23 January 2013, 19:28:50
Quote from: cem on 23 January 2013, 19:27:18
Quote from: Broomies Mate on 23 January 2013, 18:57:29
LS1 = 188 kg Wet
M62B44 = 221 kg Dry (+ 9.15l of Oil)
C20XE = 145 kg Wet
Cant find the weight of a C20LET online, but I'd imagine marginally more than the C20XE for obvious reasons.
C20let around 130 kg..
How can it be lighter than the XE?
probably similiar all I can find was this.. may be light flywheel..
aluminium block v8 is not dissimilar weight to y32se or x30xe due to having an iron block. ;)
V6 lumps out of question anyway..  they are not race bred engines.. :-\
define a race bred engine?
engines originally designed for race.. they are later put to production for daily use with lower power rating..
Such as...? :)
just google :)
Don't recall many Japanese engines being used in Nascar :-\ Surely if they're that good they would be everywhere...
Besides the LS family is alot less reliant on electronic black magic :y
Quote from: chrisgixer on 23 January 2013, 20:24:12
It is indeed, and has been done in the rats omega. But the heads are wider, being dohc. They definitely fitted a rack with that engine.
LS or LS? ;D.
Lexus is 4litre though? Although just as easily tunable. But then the Chevy v8 well, that's the one to have. But costs more.
Decisions decisions. :y
I suppose it depends which is most suitable to omega running gear. Cooling, Exhaust, Auxiliarys, ecu and security stuff....etc?
Not much matches a Chevy v8 though, its very hard to beat pound for pound on bhp. You might have to remove the box on a Chevy v8. Where as it definitely will have to come out with a dohc lump.
Plus, they had to cut the chassis on the rats omega, although its not clear exactly where. Might have been to make room for a turbo, or to make room for the heads. Chevy v8 doesn't need a turbo though, so one less job. I guess.
Broomies Mate
Quote from: cem on 23 January 2013, 20:24:44
Honda VTEC no doubt?  Dreadful, DREADFUL engines!
Quote from: ex taxi al on 23 January 2013, 20:28:03
you said reliability.. I wouldnt like to pump high volumes of oil on asphalt just in the beginning of race ;D :y
Supercharger fits neatly on top as well 8)
Nascar is an American race , isnt it ?
NASCAR is a U.S. series.They are a tad patriotic over there. :)
As for cutting the chassis etc. I have an angle grinder and a set of panel beating hammers.no worries. :D ;D
No way imo,is any U.S. engine (or anything else in the field of engineering) going to be in the same league as a comparable Jap engine/ product.Its like comparing a harley to a Honda.
Quote from: chrisgixer on 23 January 2013, 20:28:49
LS or LS? ;D .
why do you think they choose Lexus?
If you read the link cem, I'm sure it tells you. ;)
Quote from: Broomies Mate on 23 January 2013, 20:29:45
I'm afraid there are lots of enthusiasts thinking different ::)
Probably had a smashed up one lying around ::)
Technically Albs, but, hand on heart which would you prefer...
Broomies Mate
Quote from: cem on 23 January 2013, 20:36:46
A lot of people think having sex with animals is great fun.  It doesn't mean it is right!   ;)
Spotty Yoofs know nothing. Some people eat semolina, doesn't make it gourmet though (or edible) ::)
