ruff running and loss of power
Started by migman, 07 April 2013, 13:59:46
migman
hi guy's i have 1999 auto estate 2.2 petrol after an overnight stand it starts as it should then then it starts to run rough and the engine speeds rises and falls then after approx 2 mins it runs at idle speed , then when i drive it get's to 2000rpm then dies, if i put the accelerater to the floor it kicks down a goes ok till it goes back to 2000rpm, a new genuine o2 sensor fitted could anybody give me any info on problems i am having the i have had given to me are p1555, p0170,p0130, p1405 theses were given to me by th R A C . also am  i looking at mega money to fix this thanks.
Codes for 2.2 Petrol engine are here http://www.omegaowners.com/forum/index.php?topic=90576.0
P0130   O2 Sensor 1 Circuit Voltage Low
P0170   Rich Exhaust
P0170   Lean Exhaust
P1405   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High
P1405   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
P1405   Feedbacksensor Exhaust Gas Recirculation
P1555   Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load
The 2.2 has a reputation for bringing up lots of codes and distracting the inexperienced from the true fault ::)
Without access to a suitable code reader (and on a Sunday afternoon) I would start by cleaning the EGR valve. http://www.omegaowners.com/forum/index.php?topic=90553.0
symes
Mate of mine had all that-he bought new cam sensor-still same=got new throttle body -problems went?? hope yours not same
problem
Quote from: migman on 07 April 2013, 13:59:46
http://www.omegaowners.com/forum/index.php?topic=90528.0
