Author Topic: Mot fail  (Read 3469 times)
Glyn
  • Essex
    • 2.2 CDX Estate
Mot fail
« on: 02 July 2013, 14:53:52 »
Hi all
Just failed my mot.
Headlamp washers not working. :(
Is there a known problem or anything in particular I should check first.
Thanks
2.2 CDX Estate
Re: Mot fail
« Reply #1 on: 02 July 2013, 14:59:10 »
Assuming they were tested with lights on.
Green fuse in relay box by battery
If OK apply 12V to washer pump (red in pic)
If pump spins, remove it and clean filter
Glyn
  • Essex
    • 2.2 CDX Estate
Re: Mot fail
« Reply #2 on: 02 July 2013, 15:01:33 »
Thanks I'll check that when I get home
Glyn
  • Essex
    • 2.2 CDX Estate
Re: Mot fail
« Reply #3 on: 02 July 2013, 17:10:07 »
It,s the pump.
Ordered one off ebay £40. Seems a lot when the windscreen ones are under a tenner.
Mot tester says he's failed a fair few on this, as it's a relativley new test this year,
and most people are'nt aware of it, me included.
Also thanks for the pics RobG made finding the problem so much easier.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Mot fail
« Reply #4 on: 02 July 2013, 17:16:16 »
Been there, done that  :-X
Same story for me last year!
And strangely these pumps are more expensive than the windscreen one.
Re: Mot fail
« Reply #5 on: 02 July 2013, 17:41:53 »
It,s the pump.
:o :o :o Should have asked me
Re: Mot fail
« Reply #6 on: 02 July 2013, 19:20:48 »
It,s the pump.
they deliver more than 4 time the amount of water!  ;)  ;)  ;)
If you want pictures ................ RobG is the man!  :y  :y  :y
I'll have to check mine in the next few weeks before its MOT. The fuse for mine has been in the driver's door pocket for years!
« Last Edit: 02 July 2013, 19:22:36 by Andy B »
Re: Mot fail
« Reply #7 on: 02 July 2013, 19:49:09 »
£40 is daylight robbery.Cancel if you possibly can and contact RobG.  :o :y
symes
  • oxford
    • R reg 940 volvo
Re: Mot fail
« Reply #8 on: 02 July 2013, 21:15:01 »
what if you took them off---would it fail then---not there cannot fail--surely?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Mot fail
« Reply #9 on: 02 July 2013, 23:01:50 »
if they were on the car at time of build and leaving the factory, and the car has HID lamps fitted as std then yes it will fail the mot even if they have been removed.
Jaguar XJ6
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Mot fail
« Reply #10 on: 02 July 2013, 23:20:21 »
That's what I was thinking, but probably too late  :-\
Might be new though?
Glyn
  • Essex
    • 2.2 CDX Estate
Re: Mot fail
« Reply #11 on: 03 July 2013, 07:41:34 »
I agreed to buy and it doesn't seem right to cancel it.
Also it is a new one and still cheaper than the £75 stealers wanted.
Also promised fast delivery as I have ten days for a free retest.
One bonus is it only takes seconds to change. :), and quite pleased
that was all that was wrong with the car, no advisories even.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Mot fail
« Reply #12 on: 03 July 2013, 08:31:48 »
Yes, on the scale of things it was a good result, with an easy fix.  :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Mot fail
« Reply #13 on: 03 July 2013, 12:47:19 »
Is it just me or does anyone else on here think that some MOT failures are very pernickety.
I know it,s the rules but,how many lower end cars have washers? :(
Re: Mot fail
« Reply #14 on: 03 July 2013, 19:40:31 »
It's just you ;D The rules have always been straight forward in this regard... If fitted, it needs to work :y
