Pages: 1 ... 6 7 8 9 10 11 12 [13] 14 15 16 17 18   Go Down
Author Topic: Mv8 project  (Read 64605 times)
chrisgixer
Re: Mv8 project
« Reply #180 on: 03 September 2013, 23:42:55 »
Don't allow anything to hang low without protection around it, esp the way you drive.  Been there, learnt by my silly mistake  :-[
On my car, the cats sit lower than ALL of those pictured. Once I looked I was surprised I haven't hit one of those stupid speed cushions in mine. :-\
I did consider grinding it off if needs be.
chrisgixer
Re: Mv8 project
« Reply #181 on: 03 September 2013, 23:44:06 »
Oh, another thing, the mounts I have are 70mm deep. If I place a 70mm block of wood to replicate the depth of these on on the box section, with engine on top it sits too high with throttle body and pas bottle rubbing on the bonet under side.
So, unless I can find 40mm odd deep engine mounts, there work to do there. And as said the engine to mount brackets need changing too.
Rallydesign have heavy duty rubber mounts in both 35 and 50mm(both stock Ford sizes) for £6 each.
Land rovers use very similar parts, which you can find easily.
Or you could make captive ones using a suspension void bush and some tubing, like on Escort world-cup crossmembers. Although that's unlikely to be necessary on a roadcar.
Good man Nick, I'll take a look see. :y
Re: Mv8 project
« Reply #182 on: 04 September 2013, 08:55:17 »
For engine mounts I'd either;
Go for a 'bobbin' style as Nick suggests (Land/Rover V8, etc) of a suitable height - lots of different variations available, or;
Go for a universal weld on mount: http://www.jegs.com/i/Trans+Dapt/969/4501/10002/-1, or;
Search www.jegs.com or www.summitracing.com - there are about a billion* different variations of LSx mounts available
If you find what you want stateside and you don't want to personally import it, try www.topspeedautomotive.co.uk - they're round the corner from me at work so I can call in and pick bits up, and they got me a QuickTime bellhousing in from the US in under a fortnight for about the same as it would have cost me direct.. really helpful oldschool guys.
P.S. Going back to traction control - yes, RaceLogic stuff is not cheap.. I think about £800 now for a full system, but well worth it and a million times better than the Omega system, certainly the FL one.
*slight exaggeration but, really, only very slight!
Re: Mv8 project
« Reply #183 on: 04 September 2013, 14:19:37 »
Yep, I was about to recommend Rally Design too.
2woody
  • Northumberland
Re: Mv8 project
« Reply #184 on: 07 September 2013, 00:38:02 »
want a Racelogic traction control system - I have one spare......
Re: Mv8 project
« Reply #185 on: 07 September 2013, 10:15:49 »
I'm guessing gayboy wants, if at all possible, just the standard OE electronic aids, rather than aftermarket add-ons, even if the add-ons are more advanced, purely to keep the cabin standard.
I may be wrong, of course....
chrisgixer
Re: Mv8 project
« Reply #186 on: 07 September 2013, 10:59:23 »
As groomer kiddy fiddler says, really. Oe is my preference. But thanks for the offer. I'll bare it in mind.
Current area of focus is the engine mounts, rack/column and exhaust manifold side of the engine.
...And getting some welding practice in. ::)
(Thanks to Gaffers and Shakeng there :y )
2woody
  • Northumberland
Re: Mv8 project
« Reply #187 on: 08 September 2013, 00:37:25 »
no problem.
just for reference, the racelogic system is not detectable from a cabin perspective. It has one switch and one lamp, which could easily be the ones already there
Re: Mv8 project
« Reply #188 on: 08 October 2013, 11:09:53 »
Interestingly, a work collegue has a VXR8 which is currently sat at Walkinshaw Performance having this installed:
http://www.walkinshawperformance.co.uk/wp/uk/products/default.asp?content=Vauxhall VXR8&id=81
Hes due to get it back late on friday so will see if I can get a few pics next week.
Re: Mv8 project
« Reply #189 on: 08 October 2013, 11:12:38 »
VXR8 was not exactly slow before either  :o
Re: Mv8 project
« Reply #190 on: 08 October 2013, 11:53:26 »
Think he said its mid to high 500's on the bhp after.
Re: Mv8 project
« Reply #191 on: 08 October 2013, 12:45:13 »
Standard fit on the latest VXR8 iirc :y
Re: Mv8 project
« Reply #192 on: 08 October 2013, 13:23:04 »
Only the GTS variant  :y
Re: Mv8 project
« Reply #193 on: 08 October 2013, 15:33:04 »
Thought the VF was only blown :-\
chrisgixer
Re: Mv8 project
« Reply #194 on: 08 October 2013, 15:36:41 »
HooohohoHOOOOO that will be fun.
Very interesting Mark. More than my whole package put together.
Pages: 1 ... 6 7 8 9 10 11 12 [13] 14 15 16 17 18   Go Up
