Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 18   Go Down
Author Topic: Mv8 project  (Read 64385 times)
symes
  • oxford
    • R reg 940 volvo
Re: Mv8 project
« Reply #120 on: 23 August 2013, 10:57:34 »
Note to self, buy cutting discs. ;)
buy some of those very thin ones mate---but be careful not to twist as using-can shatter--and if removing tunnel might be an idea to brace body--just in case--you probably only need to remove front half anyway-I was lucky my seats just fit-dont move but they fit ;D ;D keep at it-remember
If you need to ask you probably wouldn't understand-----that works on most people when they ask silly/pointless questions
had loads of them-when cut rover in half ;D ;D
Re: Mv8 project
« Reply #121 on: 23 August 2013, 10:59:03 »
Aye, slitting discs - same as Chris was using the other day round mind to get the exhaust off my car.. ;D
symes
  • oxford
    • R reg 940 volvo
Re: Mv8 project
« Reply #122 on: 23 August 2013, 11:03:02 »
yep--I use them in mine-now got one of those tiny air cut off tool---damn good for cutting panels out :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Mv8 project
« Reply #123 on: 24 August 2013, 09:24:47 »
« Last Edit: 24 August 2013, 09:30:54 by biggriffin »
Hoof'land storeman.
chrisgixer
Re: Mv8 project
« Reply #124 on: 24 August 2013, 09:57:09 »
Wow, I've made a fortune. :o
;) ;D
chrisgixer
Re: Mv8 project
« Reply #125 on: 30 August 2013, 00:20:22 »
Re: Mv8 project
« Reply #126 on: 30 August 2013, 03:41:48 »
Some interesting stuff here. :y
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/130818-cant-wait-2.html
Posts 80-83 are particularly relevant, and clearly show that a manual box isn't the answer to clearance issues :y
Don't forget that the 1.5" engine offset is to clear the lhd steering box and ABS unit, which even then needed moving ::) rack should negate the engine clearance issues provided the steering column doesn't foul the exhaust.
BTW, those 'Corvette' brakes are the ones that fit between standard and AP sizes, so a tidy upgrade from standard Omega, (guessing the discs were custom made though as they had the same bolt holes as the Omega ones), although the Merc ML/Audi S4 set up ought to be at least comparable :-\ Similar sized discs/calipers iirc  :y
Finally from that thread, the OP has been working on the project since 2008, his last update being August last year, and that was using factory Omega V8 parts, so it might take a little while to get up and running :y
chrisgixer
Re: Mv8 project
« Reply #127 on: 30 August 2013, 08:31:29 »
Did you see the holes around the circumference of the hub area of the front discs for cooling?
Post 28.
And that a good 10-15 mm of the inner swept area of the disc is completely untouched by the pads.
Along with how simple the caliper adaptor bracket is to make in post 31.
« Last Edit: 30 August 2013, 08:37:09 by chrisgixer »
chrisgixer
Re: Mv8 project
« Reply #128 on: 30 August 2013, 08:42:48 »
Bit I must say, I didn't realise the t56 doesn't fit either. :o
Makes my issues look insignificant.
chrisgixer
Re: Mv8 project
« Reply #129 on: 30 August 2013, 08:51:15 »
Rear caliper appears to offer no increase in performance what so ever, but is clearly different. Is this the standard vented disc caliper, over the standard solid disc variant?
Re: Mv8 project
« Reply #130 on: 30 August 2013, 08:55:15 »
Think those discs are custom made using the omega hub as a base. On a Holden/Corvette the hubs are larger so the disc face would be better matched to the pad swept area :y holes around the hub are more to do with lightness I thought :-\
Looking at that thread again, the crossmember on the front subframe looks about an inch lower as well... T56 is mahoosive next to the 4L60 :o
Standard solid caliper on standard solid disc. Looking at the convesation the US rear brakes differed slightly from ours with regard to when vented rears were standard. Shame he doesn't give the disc sizes, although they are made clear on the HSV thread I linked to.
Re: Mv8 project
« Reply #131 on: 30 August 2013, 08:58:10 »
Those calipers are different to the Monaro VXR ones which arethe same size and design as the Omega fronts :y
Note to self... Stop getting up so early ::)
chrisgixer
Re: Mv8 project
« Reply #132 on: 02 September 2013, 21:41:46 »
« Last Edit: 02 September 2013, 21:44:29 by chrisgixer »
chrisgixer
Re: Mv8 project
« Reply #133 on: 02 September 2013, 21:46:45 »
chrisgixer
Re: Mv8 project
« Reply #134 on: 02 September 2013, 21:52:20 »
And the sales pdf within
http://www.opel-infos.de/downloads/omegav8_geneva_e.pdf
Which says, the omega v8 was available exclusively with automatic gear box. (Or would have been)
...and brakes capable of 10 stops from 100kph. :-\ (not mph)
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 18   Go Up
Page created in 0.026 seconds with 20 queries.
