Author Topic: Water "Adams ale"  (Read 10239 times)
Re: Water "Adams ale"
« Reply #15 on: 28 August 2013, 14:58:01 »
Just installed a rainwater capture system in my garage, actually. Pumped up to a header tank in the roof space so I can feed my pressure washer from it. :y
I got about 300 litres or more catching rain water of 2 sheds  :) Very handy  :y
Yes mine is filtered , i would drink it but only when water is as dear as gold  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #16 on: 28 August 2013, 15:06:30 »
Read the title wrong  ::)
Adnams Beer, Broadside, Gunhill, Southwold, English Red Ale, Tally Ho, Hmmm, Hic..  :)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #17 on: 28 August 2013, 16:04:26 »
Easily done  :y
« Reply #18 on: 28 August 2013, 16:58:44 »
Yeah, don't use Broadside as a coolant on a hot day.. everything goes all wobbly. :D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #19 on: 28 August 2013, 17:53:54 »
 ;D ;D ;D :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #20 on: 28 August 2013, 17:56:12 »
Could someone point me in the direction of the "HowTo" guide on a 3.2 engine coolant change guide can't seem to find one  :-\ :)
And what does everyone think about the Antifreeze choice in my #1 post. Will it be compatible ?
Thanks in advance  ;)
« Reply #21 on: 28 August 2013, 18:54:12 »
Thats what i put in mine together with soft water  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #22 on: 28 August 2013, 20:58:26 »
Was going to buy GM long life but this stuff is a decent brand and a reasonable price delivered next day free (I've got amazon prime free trial atm)  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #23 on: 28 August 2013, 22:12:05 »
Thanks tunnie this will come in handy  :y
http://www.omegaowners.com/forum/index.php?topic=90625.0
and i like the sound of this method from Jimbob  :y
"An alternative filling arrangement is :-
Repeat flushing with water only, until the drained water is completely clear.
Now drain the system again, and then close the drain tap.
The car will now have about 1/2 the required fluid (Water) in it.
Add neat antifreeze :-
for a V6 which hold 9 litres, add 4.5 litres of neat  antifreeze
for a 4 pot which holds 6 litres, add 3 litres of neat antifreeze.
You can now, top up to the correct level with water.
Run the car up to temperature, with heaters set to Hi, burping hoses to expel any air.  Topping up with water as necessary.
Any future top ups, use a 50/50 mix to maintain the concentration.
mmcg
« Reply #24 on: 28 August 2013, 22:41:43 »
Any harm using 100% coolant.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #25 on: 28 August 2013, 22:59:45 »
i'm not sure why (just got told by my teacher) but using 100% antifreeze renders it useless and as good as putting 100% water in. not sure how true that is but I wouldn't  :y
I personally just use tap water with my 50/50 mix.
RIP Paul Lovejoy
« Reply #26 on: 28 August 2013, 23:19:20 »
Ooooo this is a new concept to me!  :o  I've never thought of water hardness/softness and have always used tapwater!  ::)
What a philistine!!  :)
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #27 on: 28 August 2013, 23:21:52 »
You shouldn't do that in Northampton your water is hard, well hard. Check the instructions on your antifreeze.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #28 on: 28 August 2013, 23:22:03 »
I tend to over think things i think, Well i think i tend to at least, I think i do  ::) ;D :-X
mmcg
« Reply #29 on: 28 August 2013, 23:23:37 »
I put in a 72 rekord last year better add water. :y
