Author Topic: Water "Adams ale"  (Read 10231 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Water "Adams ale"
« Reply #30 on: 28 August 2013, 23:27:01 »
I personally just use tap water with my 50/50 mix.
You shouldn't do that in Northampton your water is hard, well hard. Check the instructions on your antifreeze.
We're all well 'ard in Northampton mate. GRRRR  :y :y :y
In seriousness I didn't know about water hardness. never had a problem before  :y
RIP Paul Lovejoy
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #31 on: 29 August 2013, 18:38:33 »
Is this the thing I should unscrew ?
Just took that picture, only thing I could see that resembled a drain plug on the passenger side of the Elite  ???
« Reply #32 on: 29 August 2013, 21:05:58 »
Put your moobs away Mr Bear ;D
The harder the water, the more minerals in it. The more hard water in your engine, the more limescale in it :'(
You don't use distilled water in your kettle and I bet you buy a new one every couple of years because it's all furred up and fubared ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #33 on: 29 August 2013, 21:57:26 »
  • Auckland
    • Mazda MPV
« Reply #34 on: 29 August 2013, 22:02:44 »
That is where it should be :-\ There should be a plastic drain plug (often red) and a spout that you can push a small hose onto to direct the coolant into a suitable containerbucket.
« Reply #35 on: 29 August 2013, 22:04:11 »
I think you should collect a sample of your coolant and send it off for analysis.  :)
« Reply #36 on: 29 August 2013, 22:15:24 »
Two things wrong with that pic...
1. That is what you unscrew, but it's a cheapy pattern radiator, so all bets are off.
2. You're one winter away from needing a new aircon condensor.
Washing up bowl under that cap and unscrew it. You can flush coolant down the toilet, but not down a street drain :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #37 on: 29 August 2013, 22:24:02 »
Ah  :(
A/C Condenser isn't that old going by receipts only a few years...
We don't have street drains just a septic tank that gets emptied every so often.
... Should be fun this job then  ::)
« Reply #38 on: 29 August 2013, 23:01:18 »
Ah  :(
Hasn't stopped the bottom row of fins from starting to fall off ::) left of your pic, just above the subframe :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #39 on: 29 August 2013, 23:14:25 »
Ah  :(
Must be a cheap pattern part. Typical of S Wales  ::) ;D
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #40 on: 30 August 2013, 11:44:54 »
As far as putting water in the kettle you are changing the water every time you use it in the car the same water stays in for at least one year and a lot longer for most cars,
« Reply #41 on: 30 August 2013, 12:16:18 »
True, but that years old water in the car is basically boiling 95% of the time :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #42 on: 30 August 2013, 12:37:06 »
But there is only a certain amount of calcium in the water and once that has deposited thats it .
« Reply #43 on: 30 August 2013, 12:40:44 »
Yes, but it's not evaporating, and it's the same water going round for years, so it only has a limited amount of scale to deposit before it's become soft water. In the same way, your central heating boiler won't scale up, even in a hard water area, heat exchangers in combo boilers excepted.
In addition, antifreeze will contain inhibitors to prevent scale forming.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #44 on: 30 August 2013, 14:20:38 »
Come to Cornwall to fill up,our water is luverly and soft down ere :y :y
other rides
