Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Water "Adams ale"  (Read 10232 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Water "Adams ale"
« Reply #45 on: 30 August 2013, 15:09:05 »
So around 5L should come out of the radiator plug, Trying to find a container big enough that will slide underneath..
Not sure where to put the waste to be honest, The septic tank has an overflow I believe to the field next to the house underground and there are currently cattle and horses in there.
« Reply #46 on: 30 August 2013, 16:58:40 »
Two things wrong with that pic...
1. That is what you unscrew, but it's a cheapy pattern radiator, so all bets are off.
2. You're one winter away from needing a new aircon condensor.
Washing up bowl under that cap and unscrew it. You can flush coolant down the toilet, but not down a street drain :y
You learn something every day on here  ;D I didnt realize you could use the bog  ::)
« Reply #47 on: 30 August 2013, 17:04:33 »
Bog water gets processed, street drains don't :y
« Reply #48 on: 30 August 2013, 17:09:30 »
Best not throw a fag down after though  ::)  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #49 on: 30 August 2013, 17:27:40 »
The antifreeze will help during the winter months from freezing the S##T  ;D
« Reply #50 on: 30 August 2013, 17:36:12 »
Not before it has killed all the cats, and wild life first
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #51 on: 30 August 2013, 18:14:38 »
You said down the Bog  ???, There should be a better system in place for chemicals like these.. Then again the excuse they could use is it should be done at a garage.
« Reply #52 on: 30 August 2013, 18:27:42 »
Local tip should have a place  :) Years ago i use to paint the fence in used engine oil and anti freeze but dont bother now .
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #53 on: 30 August 2013, 18:32:07 »
Bet they didn't get wood rot  :o :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #54 on: 30 August 2013, 18:35:11 »
Just out of curiosity does anyone know how much a VX dealer would charge to change the coolant.
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #55 on: 30 August 2013, 18:39:21 »
Our local tip has hazardous waste amnesty days or you can ring the local council and ask them. (Probably tell you to tip it down the bog ;D)
Stick it in a container,mark it up and leave it outside the local kwik fit ;D :y
PS A good source of free 5/10 ltr plastic containers for oil change etc is from your local pub/chip shop/cafe. :y
« Reply #56 on: 30 August 2013, 19:22:23 »
Flushed down the toilet is fine :y (though if you have a sceptic tank check with whoever empties it as they might pour it into the nearest stream :-\). If it has an open overflow probably not such a bright idea :-\
« Last Edit: 30 August 2013, 19:27:01 by ex taxi al »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #57 on: 30 August 2013, 19:29:36 »
Flushed down the toilet is fine :y (though if you have a sceptic tank check with whoever empties it). Using it to de ice the drive is criminal, which unless I can't read, is what You suggested ::)
Yeah on the main sewerage lines in cities etc. i'm sure thats fine, Na no i meant de-ice the sewerage pipes i.e. where the S##T travels to its destination, They freeze up here when its really cold, I wouldn't use it on a drive got pets and where did i mention the word drive  ??? ::) ;D.
Think i'm over thinking this situation.  :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #58 on: 30 August 2013, 19:32:52 »
Nearest one to me around 30 miles  :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #59 on: 30 August 2013, 19:35:50 »
That's my worry.. The company who empties it is a fairly big firm, No idea where they empty it though..
Pages: 1 2 3 [4] 5  All   Go Up
