Author Topic: Torque Guessing  (Read 3999 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
Torque Guessing
« on: 25 June 2014, 15:44:37 »
Hi Guys  :y
If I have to tighten nuts and bolts to certain Torque Nb, then how can I figure it out if I don't have any idea as to how much pressure I'm applying? Is there some quick tip to know this or a device to help?
Your input is always a light in the darkness  ???
Cheers
Ant
Still learning...Be nice!
Re: Torque Guessing
« Reply #1 on: 25 June 2014, 15:50:41 »
Torque Wrench? I use Halfords ones, I have two:
8-60 Nm
60-300 Nm
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #2 on: 25 June 2014, 15:59:11 »
8-60 Nm
60-300 Nm
I can't remember as it's ages since I had one (Torque wrench) in my hand (No jokes ???) But do they have indicators or special clicks when the desired Nb is reached?
Cheers
Ant
P.S. I'm in Spain so I'll see if there's a "Halfordos" around the neighbourhood lol!
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #3 on: 25 June 2014, 16:14:01 »
Guess that's a stupid question right?  :D
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Torque Guessing
« Reply #4 on: 25 June 2014, 16:35:47 »
There are two types: the classic 'beam' type with a scale and a pointer, and the micrometer type which clicks. They both have limitations, beam ones need a large scale and a straight pointer. The others depend on a screw and a spring, so damage is less obvious.
Cheap micrometer TWs have pretty much eliminated the beam ones.
The job most of us use them for don't require extreme accuracy, so cheap ones are easily good enough. That's a statement that will have the anoraks frothing at the mouth and building bonfires to burn my effigy, but that doesn't stop it being true!
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #5 on: 25 June 2014, 17:49:24 »
Should I guess the 8Nb for the plenum refitting?  :-\
Re: Torque Guessing
« Reply #6 on: 25 June 2014, 17:59:25 »
Cam Covers  :y
  • Chatham, Kent
Re: Torque Guessing
« Reply #7 on: 25 June 2014, 18:26:32 »
Guess the plenum bolts, the 'correct' figure is not important.
8Nm for V6 cam-covers should be done with a torque-wrench, about the only place I bother with such a low figure.
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #8 on: 25 June 2014, 21:19:03 »
 :y :y
chrisgixer
Re: Torque Guessing
« Reply #9 on: 25 June 2014, 22:09:25 »
No!
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Torque Guessing
« Reply #10 on: 25 June 2014, 22:13:16 »
No!
Best answer ever in the history of OOF ;D ;D ;D
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #11 on: 25 June 2014, 23:14:46 »
No!
No What?  :-\
Re: Torque Guessing
« Reply #12 on: 25 June 2014, 23:21:00 »
No!
No What?  :-\
[/highlight]
Chris plainly means NO you shouldn't guess the torque setting for the cam covers Anthony ::)
In fact ::), "guessing" any torque setting is foolish and unnecessary since torque wrenches can be bought reasonably cheaply :y
Anthony in Madrid
  • Valencia, Spain
Re: Torque Guessing
« Reply #13 on: 25 June 2014, 23:40:29 »
No!
No What?  :-\
[/highlight]
I need to take off the plenum, not cam covers amigo.
That's the only job at the moment.
Do the bolts need an exact Nh?
 :-[ :y
Re: Torque Guessing
« Reply #14 on: 25 June 2014, 23:59:20 »
No!
No What?  :-\
[/highlight]
 :-[ :y
These might help  :y
http://www.omegaowners.com/forum/index.php?topic=90657.0
http://www.omegaowners.com/forum/index.php?topic=90545.0
