Author Topic: Central locking help please!  (Read 1456 times)
smalt36
  • hull
    • Omega2.2GLS
« on: 08 July 2014, 16:13:25 »
Hi folks, as I finally got the miga through mot its time to sort the other niggly things out. 1st is the central locking, this was fine until one day it stopped working, I had to really force the drivers door lock with the key to get it to open but once open it works as a noirmal door would with a key. None of the other doors open when i lock/unlock the drivers door but the alarm arms/disarms with the remote so that part of it is working. Just found fuse no.20 was blown, have replaced it but still no joy, also tried re-syncing the fob but again no joy. Should I start with drivers door motor or central locking ecu??
Sorry its long winded but tried to give as much info as poss!
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Central locking help please!
« Reply #1 on: 10 July 2014, 09:00:55 »
Sad to see a newbie getting no reply I only wish I could help,this might prompt experts to reply. :y
« Reply #2 on: 10 July 2014, 10:23:17 »
I believe the most common failure is of a microswitch inside the door motor, there's a guide on repairing it:
http://www.omegaowners.com/forum/index.php?topic=90642.0
And a guide on replacing the motor:
http://www.omegaowners.com/forum/index.php?topic=90504.0
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 10 July 2014, 20:38:40 »
Got some spare motors for sale if you need one  :y
unlucky alf
  • worksop, notts
« Reply #4 on: 10 July 2014, 21:28:43 »
Just as well to change the drivers door c/l motor, Both front door motors are the same so should be easy enough to get hold of. :y
smalt36
  • hull
    • Omega2.2GLS
« Reply #5 on: 11 July 2014, 21:42:33 »
Thanks Robson thought i'd done something wrong ???! Yeh will start with the motor and see what happens, how much do you charge omegod i'll have one off ya :y Cheers for the replys folks
