Engine Loom
Started by Steve B, 18 February 2015, 18:19:05
Steve B
#285
Quote from: Marks DTM Calib on 24 March 2015, 15:20:00
Which hints towards the coil pack being fired on the wrong stroke for some reason.
So other than the cylinder head, nothing else has been changed?
On this bank the cams have been out twice...
The first time so we could turn the pistons over to have a good look at the bores on bank 2
And then out again owing to us getting the G & J cams the wrong way round on this bank
Ok, and the cam sprockets were fitted correctly e.g. exhaust aligned to notch 1 and inlet to notch 2?
(note: just checking the obvious  :y)
Quote from: Marks DTM Calib on 24 March 2015, 16:01:55
Yep, the 1-3-5 exhaust cam was fitted into keyway marked '1' - and the inlet cam into the one marked "2' - I'm pretty sure I got steve to check, before I tightened them, just for absolute certainty....
I'm starting to think we need to check this again, though...
I don't suppose something daft like the cam sprocket dowel could have come adrift  :-\ The cam was held using the hex part at the end, and the pulley bolts correctly tightened...  :-\
I am just working through the basics of what could cause the issue.  :y
On the 1-3-5 bank, the key way slots are 180 degrees between each so no valve damage but the spark will be firing on the wrong stroke.
I assume no paper towels have been left in the inlet or similar?  :y
Steve B
Quote from: Marks DTM Calib on 24 March 2015, 16:18:29
No chance
The bottom line is, when the 1-3-5 cams were in the wrong place, it ran OK at idle, albeit a bit lumpy, it would run unassisted, and then eventually put the misfire codes up for that bank.
Since the cams were swapped into the right place, the engine immediately ran like a sack of poo with immediate misfire codes on that bank
Although we are confident on the pulley fitment and timing etc, I can't help thinking we need to go over this again, and inspect the camshafts/lifters etc very closely...
Considering that you have good compression and the lifters are quiet would suggest that the valves are ok.
Its confirmed that the spark is (possibly) good and fuel is there, so there must be a more fundamental reason why the engine is not firing on that compression cycle.  :y
There is some popping and banging when the ignition system is connected hinting that something is burning all be it at the wrong time.
Quote from: Marks DTM Calib on 24 March 2015, 16:36:40
My gut feeling is that we whip the belt off and check the camshaft sprocket alignment to be absolutely certain of this, even if to rule it out :-[
It might be easy enough to check just by removing the cam cover.
Steve I might try and get up to you tomorrow, I won't be able to do a late one though as I'm working earlies the next day...  :y
Steve B
Do you want me to strip down get the cam cover off get engine at TDC and get camera out  :-\
Pop the cam cover off and set to TDC with cam timing marks aligned as per belt fit (pop the bolts out the top of the timing cover so you can ease it back to see), observe the cam lobe positions on no1 cylinder (they should both be pointing upwards).
Quote from: BIGtime on 24 March 2015, 16:45:16
You would find TDC roughly by eye, when no1 is at the top of it's stroke and the cut out on the crank sprocket is at 6 o clock... but if you're not confident, I'll do it for you..
I'm just aware that after tomorrow, I'm working for about ten days straight, so wouldn't get up to you until around 06 April, unless I booked a day off..
Quote from: JamesV6CDX on 24 March 2015, 16:47:44
Timing mark at 2ish on the pulley/cam belt cover  :y
But cam timing marks need to align with rear cover to   :y
Quote from: Marks DTM Calib on 24 March 2015, 16:56:18
Sorry.... I was referring to the crank sprocket (the one the belt runs on) being at 6pm at TDC, rather than the outer pulley which drives the aux belt - as you rightfully say this would be at 2pm :y
