Engine Loom
Started by Steve B, 18 February 2015, 18:19:05
Steve B
Quote from: Kevin Wood on 19 March 2015, 17:12:10
Just upload a CSV / Excel file somewhere with all the readings in.. assuming you're using the reader that shall remain nameless.
I took 12 live data readings owing to fault codes coming so stopped to reset codes...These reading start  from cold and go until tha fans kick in...
Like you say,They are CSV files and you need  Excel or star office to read them
https://dl.dropboxusercontent.com/u/70807181/take1.csv
The open circuit lambda is likely to be because I left one unplugged after testing stuff, no concern there
When are you free for me to come and play in daylight? :y
Steve B
Quote from: JamesV6CDX on 19 March 2015, 22:59:24
i thought that  ;D
Quote from: BIGtime on 19 March 2015, 23:13:25
i thought that  ;D
It was a frigging long day :y
Are you about either tomorrow or Monday for more playtime? :y
Steve B
Quote from: JamesV6CDX on 19 March 2015, 23:14:57
i thought that  ;D
Why didnt you say  ;D ;D ;D ;D ;D
Its not ignition. Its not Fuel..  Its a vac problem i think.... Thats all it can be... :-\
Hope so, but then again, it was just a misfire... ::)
The brake servo vacuum pipe does come from bank 1/3/5. Think about how the intake manifold ports cross over. ;)
Would be worth blanking it off just in case..
Live data shows quite a high MAF reading, even given the cold engine. I suppose that might not be surprising if it's trying to sustain an idle on 3 cylinders. Look what happens to Bank 2 ST fuel trim before it gives up and opens the loop, too. :-\
Steve B
Quote from: Kevin Wood on 19 March 2015, 23:50:03
e..
Thats the area im thinking too..... Tomo Gonna blank the servo bung...(but with that you move over to faulty servo thoughts) And have a good check of the vac pipes with a suckarometer For a split.
Have a spare MAF but once james unplugged the one fitted it never made much change it just went to the ECU default.
PS: thanks for your input  :y
Yes indeed it shoots upwards!
This would tie in with the theory of it running rich, and the other bank lean, no?
Quote from: BIGtime on 20 March 2015, 00:05:23
e..
Do you want to leave it until I get there? We can look together in daylight with clear heads :y
I can head up late morning ish :y
Steve B
#251
ok james   and yes MAF reading are a little up from before  :y
Top is before we played around.... Bottom is now . :y
14Kg/h is right on the money for a warm engine. It will be higher when in cold start, of course.
Steve B
Quote from: Kevin Wood on 20 March 2015, 09:18:19
And it can be seen from the bottom pic that our MAF reading is too high at the Moment  :-\
Quote from: BIGtime on 20 March 2015, 09:25:52
So what changed between the two readings?
If there is a serious misfire, I'd expect it to be a little high, as said.
