Airmatic problems now
Started by Andy B, 19 January 2016, 13:20:39
Crazycarzowner
The pump itself is a doddle to refurbish. Its literally a piston & ring in a cylinder. The piston ring gets worn out due to over use and looses compression. For Land Rovers at least, you can buy a refurb kit at about £30, so they should be available for Mercs  :-\ :-\ :-\
Quote from: Jasonm on 21 January 2016, 12:18:11
...... you can buy a refurb kit at about £30, so they should be available for Mercs  :-\ :-\ :-\
I don't know,  but I wouldn't bet on it  ;)
Worth looking at. :y
Its highly likely there the same manufacturer given neither Merc nor Land Rover make suspensions components
Similar system on my last Jag (X350) - Jag don't do refurb kits only a new compressor at £350.  However Audi do a refurb kit @£25 - the compressors being same make and model.  Reasonably easy to remove compressor and refurb.
Worth googling compressor model number & see if it throws up a refurb kit  ;)
Diamond Black Geezer
Quote from: dbug on 21 January 2016, 15:33:52
Goes to show there's two sides to every part number.  :y  Land Rover in particular have the most incredible, comprehensive spares availability I've ever seen, and at bleeding cheap prices, too. Here's hoping you get sorted soon.  :)
If only it was a simple as a compressor that's failed.
I'll photo that side tomorrow, it looks like one of these slammed to ground Yank Tanks ... but just on one corner  ;D
Have you narrowed down the fault yet? Still unsure if it's bag, or something else, yes? You've probably been googling 'airmatic' left right and centre, but I did find this forum thread which may be of some help.. they do reference a failed relay, though I'd imagine two wheels/all four would fail in such an instance.
http://mbworld.org/forums/s-class-w220/243997-air-matic-failed.html
Quote from: Diamond Black Geezer on 21 January 2016, 15:52:45
Have you narrowed down the fault yet?  ....
Not yet, work has got in the way. I only noticed it Monday morning, busy the rest of the day, Monday late afternoon it'd gone back down. In work Tues Wed & today 8 till 8 so not even looked under the wheel arch  ;) ;)
..... and thanks for the link  :y :y
I suppose, stupidly low-tech as it may sound, some soapy solution may help.
...and now the punchline...
and then you could use some on your suspension, too.
Boom. boom.
Quote from: Diamond Black Geezer on 21 January 2016, 16:12:39
Boom. boom.
Oooer!  ;) ;)
That was actually part of my diag plan  :y
henryd
It was an Audi allroad kit that fitted the Discovery 2's pump :y :y
other rides
Quote from: Diamond Black Geezer on 21 January 2016, 15:41:47
Yes, a lot of which is tat and rubbish.....Britpart being a classic example.
Fair enough! No personal experience of Landie stuff, just went by what I was showed by a mate/OOFer who is doing up an old Range Rover Classic. I think it was the dealer's own parts catalogue he showed me, thicker than a big-print version of the King James Bible it was! As far as I was aware it was genuine Dealer stuff, but may have been aftermarket, I don't know for certain.
Probably Rimmer Bros, having had to maintain about 5 Land Rovers for the last 6 years you soon learn just how awful some parts are!  :y
Wheel cylinders and bearings are a classic example as are seals.
